Transmission heater? - Ford Truck Enthusiasts Forums
Old 03-27-2011, 12:49 PM
Roasted7's Avatar
Roasted7 Roasted7 is offline
Roasted7 is gaining momentum as a positive member of FTE.
Is there a heater of some sort in the tranny on these trucks? I ask because my tranny temp gage comes up within less than one minute after startup first thing in the morning no matter how cold. It'll reach nearly it's normal position before the engine temp gage even budges. I can't believe that it could warm up so fast without help. It seems to act as though it's reading exhaust temp.
Old 03-27-2011, 01:27 PM
fomoco60's Avatar
fomoco60 fomoco60 is offline
fomoco60 is starting off with a positive reputation.
That is just an example of the dash gauges being completely useless. It can easily take 30 minutes of highway driving in cold temps to get the tranny up to operating temp.
Old 03-27-2011, 01:45 PM
ljutic ss's Avatar
ljutic ss ljutic ss is offline
ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.
Most likely, you have a faulty TFT sensor in the trans.
Old 03-27-2011, 01:49 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Quote:
I doubt it. My tranny is almost to the middle mark when the Scangauge has the actual temp still under 100 degrees. Got two neighbors trucks that have similar readings. The factory gauge works more like a stepper swich with not enough levels in it. Junk!
Old 03-27-2011, 02:24 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
it also has a thermistate in it
Old 03-27-2011, 03:42 PM
ljutic ss's Avatar
Quote:
Originally Posted by 69cj View Post
I doubt it. My granny is almost to the middle mark when the Scangauge has the actual temp still under 100 degrees. Got two neighbors trucks that have similar readings. The factory gauge works more like a stepper switch with not enough levels in it. Junk!
The OP said his gauge reads in the middle in less then 1 minute, I'll bet his actual trans temperature starting in the morning will increase less then 5 degrees in 1 minute.
Old 03-27-2011, 03:48 PM
Zmann's Avatar
Zmann Zmann is offline
Zmann has a very good reputation on FTE.Zmann has a very good reputation on FTE.Zmann has a very good reputation on FTE.
Quote:
to clarify for the OP
the Transmission will reduce flow to the external cooler while it is heating up
it also has a cold shifting strategy to help it warm up faster
Old 03-27-2011, 04:10 PM
Roasted7's Avatar
I'm leaning towards the crappy guage. Sure bugs the hell out of me though.
Old 03-27-2011, 04:18 PM
Jakebrake's Avatar
Jakebrake Jakebrake is offline
< Samantha...my Co-Pilot
Jakebrake has a good reputation on FTE.Jakebrake has a good reputation on FTE.
Get a set of guages or a monitor of some type for accurate trany temps. The stock guage is pretty much worthless in my opinion.
Old 03-27-2011, 04:30 PM
GIGGER's Avatar
GIGGER GIGGER is offline
Posting Legend
GIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputation
Roasted, you need to get yourself a good set of gauges, like an Edge CTS or whatever..........
Old 03-27-2011, 06:03 PM
Roasted7's Avatar
Quote:
Yes,I plan on it but I've got to address some other issues first so it'll probably be a couple months before I can get some real guages.
Old 03-27-2011, 06:21 PM
69cj's Avatar
Quote:
Get a ScanGauge ll. Multiple gauges for 159 bucks. Best bang for the buck in my op. Plug & play to the obd ll connector.
Old 03-27-2011, 09:03 PM
BLADE35's Avatar
+1 for scangauge
they just added a bunch more x-gauges thats not listed on the scangauge website plus ficm,and a bunch of others
and I wonder with the transmission temp . At idle in park only half the torque converter is spining creating alot of energy that is going nowhere therefor heating the fluid up fairly quick
Old 03-27-2011, 10:13 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
At idle in park all of the torque converter is spinning. There is very, very little energy being used in the converter. In gear only half is spinning. Now there is significant energy being used, which will heat the fluid. In park there is almost no heat being added to the ATF.
The stock gauge is calibrated to be in the middle of the range when the trans temp is between 50 and 230F.
Old 03-27-2011, 10:51 PM
Roasted7's Avatar
Quote:
So at idle you're saying the trans temp goes from -20 degrees to +50 degrees in 30-60 seconds?
pegged the trans temp gage bobv60 6.0L Power Stroke Diesel 5 06-04-2015 09:51 PM
Temp Gage help Charleston Bronc 1987 - 1996 F150 & Larger F-Series Trucks 7 05-08-2015 04:54 PM
Overheating 97 F150 riverbottom 1997 - 2003 F150 5 08-20-2009 09:25 PM
Why wont my 7.3 get up to temp? Butch(OH) 1994.5 - 1997 7.3L Power Stroke Diesel 15 11-21-2007 04:32 PM
alternative gages for the shop Twohands Garage & Workshop 3 03-03-2007 07:24 AM
Tags
2006, 350, canada, diesel, engine, f250, ford, heater, heaters, heatet, put, trammision, transmission, trasmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
