45 gallon steel gas tank - Ford Truck Enthusiasts Forums
Old 03-27-2011, 01:42 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
I was wondering if anyone has any knowledge on the 45 gallon steel tank that JBG has.
Ford Bronco 45 Gallon Steel Gas Tank
It says that it onlyfits up to 89. I was wondering if it would fit on my 95 351w. I don't know of any significant changes to teh Bronco those years as it say it will fit both carbed and FI setups. Maybe they went to a return set-up in 90? If anyone knows if this will fit and/or has any good/bad things to say about this tank, I'm all ears. Thanks
Old 03-27-2011, 02:08 PM
Encho's Avatar
Encho Encho is online now
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
The only change, and i'm not completely sure, was on the fuel pump, can someone confirm this?.
Old 03-27-2011, 02:41 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
The difference IS related to the fuel pump setup. Ford went to the single high-pressure pump in the tank in 1990 and when that happened the locking collar and hole that the pump/float assembly goes into changed diameter. That is why it is only listed to fit through 1989.
Old 03-27-2011, 02:48 PM
Edgethis's Avatar
Ok thanks guys that's what I neede to know. Too bad they don't have a tank like that for 90 and up.
Old 03-29-2011, 09:20 PM
helirich helirich is offline
helirich is starting off with a positive reputation.
I bought a 40 gal tank for my old 88'. I took all good parts off that truck and transferd them to my 90'. (including the tank.) I just put a high pressure pump on the frame rail like the 88. I like it there better anyways. If you really want some range, check out the 50 gal aux tank in my gallery.
1994 Ford F250-Looking for a larger rear mounted fuel tank Ex-ChevyOwner Fuel Injection, Carburetion & Fuel System 2 10-18-2015 04:42 PM
Fuel Tank Specs Thunderhorn 1978 - 1996 Big Bronco 1 05-01-2014 09:18 PM
Will a 78/79 Bronco gas tank fit my 78 F150? fordman75 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-02-2012 09:10 PM
No extra capacity rear fuel tank for a 91??? archangel 1987 - 1996 F150 & Larger F-Series Trucks 6 10-17-2007 10:41 PM
Gas Tank Size Mike Cook Bronco II 11 05-12-2004 01:58 PM
Tags
1995, 45, 96, big, bronco, bronco45, ford, gal, gallon, gallons, gas, gasoline, steel, tank, tanks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
