Help with some measure
Hello
I want some help with a measure. I should put my radiator saddle in place but idont have the valance and inner fenders there.I want a lengt measure from fire wall to the bolt hole nerest fire wall on the radiator saddle.i hope i explain it so easy i can.On the fire wall you can take it from the edge the the hood land.
Anders
Anders
on
Mine also has a Volare clip, but it is a 53 with a highly modified firewall, read I had to remake it to fix the huge hole the PO cut in it.... so my measurements would be useless to him..... but the front xmember only has two holes for the two rad saddle mount bolts.... although I seem to remember they are slotted for a little adjustment... but then again it isn't an original frame.......
Normalbloke
05-23-2013 04:47 PM
