Lower steering column?
I have a 66 F250 and recently the cab mounts have gave out a bit and the lower steeering column was resting on the shaft. upon inspection it looks as if there should be a race or bearing or something. all I have is the column tube and the shaft coming out. can anybody tell me what I should have there as far as a bearing, any sort of retainer or anything? thanks
Shane
Shane
Shane, Yeah, it should have all that stuff.
There is a race at the bottom of the column with a bearing, and there is a retainer that goes around the steering shaft that is held in place by a clamp, although it doesn't actually retain the bearing itself, but centers the shaft inside the column.
I am surprised you can even steer it or shift, unless it is a 4-speed.
C5TZ-3D681-B (replaced C5TZ-3D681-A) .. Steering Column Lower Bearing Retainer / Ford just obsoleted this part.
Fits: 1965/66 F100/250 2WD with manual steering / 1967/72 F100/250 2WD & F350 with manual steering / 1969 F100/350 from serial number D96,001 & 1970/72 F100/350 with Ford P/S / Misc. 1973/79 F100/350 2WD.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 37 = 800-476-9653.
PARTS INTERNATIONAL in Farmers Branch TX has 50 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 57 = 800-543-4959.
C3DZ-3517-A .. Upper/Lower Steering Column Bearing / Available from Ford.
This bearing and its race is a one piece assembly, comes packed w/white lithium grease.
Fits: 1961/72 F100/250 2WD / 1961/65 F100/250 4WD-Upper / 1966 F100 4WD-Lower / 1967/72 F350 / 1967/70 F100 4WD-Upper / Some 1973/79 F100/350's.
MSRP: $10.68 // FTE sponsor PARTSGUYED.COM price: $7.69.
B1AZ-3518-A .. Upper/Lower Steering Column Bearing Sleeve (white slotted nylon piece shown in post # 4) / Available from Ford.
Fits: Same applications as above.
MSRP: $10.12 // PARTSGUYED.COM price: $7.28.
Southtarnation
12-20-2015 10:30 AM
Mercmeister
15
01-29-2015 01:35 PM
Shadowrider123
06-10-2014 10:28 PM
highboy 74
11-24-2004 06:35 PM
