IWE SYS. GRINDING - Page 2 - Ford Truck Enthusiasts Forums
IWE SYS. GRINDING
Old 04-09-2011, 05:11 PM
m@m m@m is offline
m@m is starting off with a positive reputation.
Well just finished putting in the lft bearing hub assy.took it for test only 40 miles all speeds and road conditions [NO GRINDING] time will tell. everything on the IWEsys. had to be changed except for the vacum lines.
special thanks to [XJCAMAR 089 AND gcozmo]
Old 04-09-2011, 07:00 PM
gcozmo's Avatar
gcozmo gcozmo is offline
gcozmo is starting off with a positive reputation.
Sounds Good!! Hope it works out for you!
Old 02-12-2015, 10:11 AM
teammaico teammaico is offline
teammaico is starting off with a positive reputation.
Front end grinding
I have just gone through all this grinding and repair and it is still there. The computer shows it is something to do with the traction control. My truck is lifted and i think it is something to do with Roll control if these trucks are equipped with that. My truck grinds on semi hard right turns, if the traction control is trying to slow the left from to keep truck from rolling or sliding that makes sense. The mechanic could prove it buy 1. removing the fuse for traction control, grind went away. 2. he turned it off from the dash button, grinding went away. I do believe this is a software problem in the traction control system.
IWE/ front end grinding noise finally fixed! But not the usual suspect! awq134 2009 - 2014 F150 14 10-21-2016 09:50 AM
IWE solenoid jdecker Clutch, Transmission, Differential, Axle & Transfer Case 6 11-27-2015 07:37 AM
Iwe replacement question for those who have done it themselves...What kind of grease? awq134 2009 - 2014 F150 6 06-27-2015 07:32 AM
Does my 2010 F150 4X4 have an IWE Solenoid? teammaico 2009 - 2014 F150 2 01-29-2015 04:03 PM
tsb for iwes....grinding noise. tomdoggie 2004 - 2008 F150 1 07-27-2009 04:57 PM
Tags
05, 2004, changed, check, f150, fix, grinding, iwe, locked, picture, repair, stuck, trucks, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
