TECH question 1996 F250 5.8 (fuel delivery)
I had the engine rebuilt and set everything in a buttoned up properly. There is no fuel getting to the fuel rail. It sounds like the fuel pump is cutting on for just a second and cuts back off. Surely this can't be as simple as a stopped up fuel filter???? When I put gas in the throttle body, it'll try to start.
BTW, it was running when I took the motor out and set up for several months. Suggestions?
Also, if someone had a pic of the drivers side of the top of the engine where the coil pack is they could post, I'd appreciate it. There is about a 1" black tube on that side facing the front of the truck just behind the oil fill that I can't find what connects to it. Like I said, It's been several months and my memory isn't the best in the world.
Thanks for the help!
ouch hope you are well i believe that hose goes to your air filter box as for the fuel have turn it on and push the fuel rail valve (looks like a valvestem) and dont be in the way it should hit the hood i cant remember the pressure but like 40 to 60 psi (im sure i will get corrected on that ) and you might even try to cycle the key on a few times and then off but dont crank the motor over do this a few times then try to start
Gotcha. I don't have any electronic sensors on my hoses or air box that I can see. I'm going to change out the filter anyway. It should just squirt gas freely with the filter out of the way, right?
Also, with my cat removed, buy sensor still in place, will that give the computer any false codes?
