2009+ 5.4 spark plugs. Same 2 piece? When to change? - Ford Truck Enthusiasts Forums
Old 03-27-2011, 08:43 AM
Paulford8's Avatar
Paulford8 Paulford8 is offline
Paulford8 is starting off with a positive reputation.
Does the 2009 5.4 still have the 2 piece plug? Has anybody changed their plugs yet? I already have 20K and dont want to leave 2 piece plugs in much longer if that is what I have.
I thought about just waiting until the end of the warranty period and having the dealer change, but nixed that thought. The dealer charges mega coin for just about everything anymore.
Old 03-27-2011, 01:45 PM
Mgizler Mgizler is offline
Mgizler is starting off with a positive reputation.
I talked to the parts manager where I bought my 2010 and he said when the 5.4 went flex fuel capable, they changed the plug design. Its no longer a 2 piece like the previous design. I was also concerned and trying to gather info.
Old 03-27-2011, 05:16 PM
LCPullman LCPullman is offline
LCPullman is starting off with a positive reputation.
They changed mid year 08 so if you have a 09 or newer you shouldn't need to worry about the 2-piece design.
Old 03-27-2011, 06:41 PM
arno arno is offline
arno is starting off with a positive reputation.
True, but still concerned.....have not found anyone who has changed them yet. I have an 09 26000.
Old 03-27-2011, 06:44 PM
Paulford8's Avatar
Quote:
You have higher miles then me, maybe you should be the guinea pig
Old 03-27-2011, 06:52 PM
Trying not to be that guy!
Old 03-27-2011, 08:52 PM
fordtorque fordtorque is offline
fordtorque is starting off with a positive reputation.
the 2009+ 5.4 liter triton engine has a stronger one piece design that will not gather carbon on the tip to cause the plug to be stuck in the hole.i work at a ford dealership and have done many 2009 f150 5.4 spark plugs with over 100 000 kms and were not a problem to take out.i know this may sound crazy,but you should have no problem at all leaving them in there for 200 000 kms or 125 000 miles without breaking them.
the only conern i've have with the 2009 5.4 was where they got the spark plugs changed and the tech globbing anti seize (lubricant/greese) on the tip and threads of the plug.the extreme heat of the engine will liquify the anti seize causing it to running down into the tip of the plug fouling them causing extremly bad misfires.
the 2009+ engines do NOT need anti seize on them to prevent breakage because they do NOT break as they are a newer ONE piece design.
Old 03-27-2011, 10:17 PM
Sounds great! Hows the job of changing plugs on an 09+ overall?
Old 03-27-2011, 10:40 PM
the overall job i'd say is actually pretty easy as far as not removing half the engine compartment to reach the plugs.they isnt as much stuff you have to remove.pretty straight forward,alot more space then the 2008 and previous models.
Old 03-28-2011, 08:08 PM
Fasttimez's Avatar
Fasttimez Fasttimez is offline
Fasttimez is starting off with a positive reputation.
Yeah the later model 5.4's are very straight forward. The earlier models were a 50/50 shot at the plug leaving it's better half stuck in the cylinder head. Just seems like yesterday we were having to do the ole "turn the plug 1/4 turn, spray PB blaster or whatever in the spark plug hole to let it work it's way around the plug, let them sit for awhile and then attempt to remove them, hoping they would come out in 1 piece"...lol You should be fine with the 2009 model.
Old 03-07-2014, 12:34 AM
boomhauer89 boomhauer89 is offline
boomhauer89 is starting off with a positive reputation.
I just changed the plugs in my late modle 08, I had a coil pack go bad right after so I changed it and it ran great for a few days then started skipping like crazy, on the cylinder with the new coil but the coil wasn't bad and just changed the plug again and it still does it, but the skipping will go in and out, any ideas?
Old 03-07-2014, 03:57 AM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
Quote:
Yep. One big idea. Go buy a new keyboard, because apparently your punctuation isn't working properly. Once done, rewrite your post into something approximating English.
Old 03-07-2014, 07:30 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Quote:
This isn't the kind of help he was looking for.
Old 03-11-2014, 05:29 PM
marksp marksp is offline
marksp is starting off with a positive reputation.
2009 5.4L spark plug change
I can attest to all the other threads that the 2009 5.4L plugs are of the 1 piece design and come out like a normal plug without any concerns. I am an ASE double master tech with 27 years experience and I own an 09. Do yourself a favor and dont fall into any of the "our plugs give you more power" advertising scams. Plugs like accel or E3 can actually cause more problems than not in certain engines. Stick with Motorcraft OE plugs and you'll have no concerns.
Old 03-11-2014, 06:10 PM
Just bough the plugs from Ford(a bit over $100!) and will be doing the swap ASAP. Ill post the results when done. Truck currently has 74k on it.
Any issues/advice for 2011 5.4 Expedition plug change? gibsonj 2007 - 2014 Expedition & Navigator 10 02-14-2017 03:22 PM
2009 5.4l valve cover torque canuck2a 2009 - 2014 F150 1 06-13-2016 12:42 AM
HELP with coil pack and plugs 2009 250 Tommy B405 1999 to 2016 Super Duty 1 08-05-2015 08:38 AM
2009 5.4 engine issues? Ziob 1999 to 2016 Super Duty 0 07-16-2015 05:26 PM
Looking at buying a 2009 F250 with a V10 f250mtnbikr Modular V10 (6.8l) 9 03-13-2015 07:38 AM
Tags
2009, 2piece, 54, changing, chips, computer, engines, f150, ford, ltr, plugs, replace, replacement, replacing, spark, v8, years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
