2009+ 5.4 spark plugs. Same 2 piece? When to change? - Page 2 - Ford Truck Enthusiasts Forums
Old 03-26-2014, 12:25 PM
Dirtrag99 Dirtrag99 is offline
Dirtrag99 is starting off with a positive reputation.
My 2005 F150 FX4 5.4 is in the shop for head repair and the shop told me they are going to install Champion 515 in place of the motorcraft presently in it. They apparently, according to the shop tech, have had way much better luck with the Champions as opposed to the motorcraft. The engine (truck) has 114500 miles on it. I was going to install some E-3s that I had but was advised against it. I wonder why? The E-3 is a one piece as opposed to the dreaded 2 piece. Any suggestions would be greatly appreciated.
Thanks
Old 03-27-2014, 09:13 AM
marksp marksp is offline
marksp is starting off with a positive reputation.
2 piece spark plug
As far as a repllacement plug, as long as you put nickel anti-seize on the new plugs they will come out much easier in the future. I would also replace them a little earlier as far as mileage. I have heard nothing good about E3 plugs including my own experience with them in numerous vehicles.....stick with either OEM Motorcraft or Champion plugs.
Old 05-29-2014, 02:14 PM
Worththewait Worththewait is offline
Worththewait is starting off with a positive reputation.
Guys,
I was told by the dealer that it was a $500.00 job to replace the plugs. I told them they were nuts and was going to do it myself. The Service Manager told me not to try it myself because the plugs get stuck in the block and because they break off and fall into the cylinder. When I got home I looked at my trusty Haynes manual and this is what it states "Ford has issued TSB 08-7-6 stateing that attempting to remove the spake plugs is likely to result in extended electrode breaking off in the cylinder head" It goes on further to explain this is for engine builds before 10/07.
I have been changing spark plugs on my own vehicles for ever, this is the first time I am a little nervous. I have a 2010 with a 5.4 should I be concerned or what? Any thoughts?
Old 05-31-2014, 11:43 PM
red89 red89 is offline
red89 is starting off with a positive reputation.
Ah excuse my ignorance guys,seeing that any late model effie is as scarce as hens teeth and worth a small fortune out here in australia,what does a 2 piece spark plug look like,they sound like they are a real pain in the A.
Old 06-01-2014, 04:27 AM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
D8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud of
Quote:
Originally Posted by Worththewait View Post
Guys,
According to the thread the plug design was changed mid-year 08 to a 1 piece design. I would take that as they will not break since they are no longer the 2 piece design, however I haven't changed plugs in mine yet. I will more than likely do mine myself when I'm closer to 100K
Old 07-03-2014, 11:13 PM
mike460's Avatar
mike460 mike460 is offline
mike460 is starting off with a positive reputation.
Guys,
I was told by the dealer that it was a $500.00 job to replace the plugs. I told them they were nuts and was going to do it myself. The Service Manager told me not to try it myself because the plugs get stuck in the block and because they break off and fall into the cylinder. When I got home I looked at my trusty Haynes manual and this is what it states "Ford has issued TSB 08-7-6 stateing that attempting to remove the spark plugs is likely to result in extended electrode breaking off in the cylinder head" It goes on further to explain this is for engine builds before 10/07.
Do it yourself. The 2010 has the revised plug and it is easy easy easy. Literally got done less than half an hour ago with my 2010 Expedition with 90k miles. Took 55 minutes from opening the toolbox to everything put up and hands clean. The passenger side is a smidge easier than the drivers side to me at least.....it was pretty tough gettin the torque wrench in on the drivers side. I bought Motorcraft plugs on Rockauto for like $65. No way I'd pay anybody more than $100 for labor on a 09 up 5.4. $500 even with parts is ludicrous.
Old 07-10-2014, 12:58 PM
Thanks Mike460 good to know. I will update when I do them.
Old 07-15-2014, 09:36 PM
Cruiser64's Avatar
Cruiser64 Cruiser64 is offline
Cruiser64 is starting off with a positive reputation.
I thought I read somewhere that when they changed the plug design they also changed the color of the cop. Can anyone help clear my head on this? Something about either a black cop or possibly a brown cop but can't remember which was good.
Old 03-07-2016, 07:05 PM
skiandride's Avatar
skiandride skiandride is offline
skiandride is starting off with a positive reputation.
I replaced the 2 piece plugs and coils on my 2006 F-150 5.4 last fall. 120K. Used Seafoam through the intake, did the 1/4 turn of each and let them soak, and soak, 1/4 turn and soak. ALL came out without breakage. Patience is the key. Replaced with one piece Motorcraft plugs and Accel coils. The OEM two piece plugs I took out....UGH..... But they're gone now. Have 145K and running well. Going to trade it or sell it this summer and am currently looking for a 2010 or 2011 to avoid this job next time.
Old 03-08-2016, 09:30 AM
WXboy's Avatar
WXboy WXboy is offline
WXboy is starting off with a positive reputation.
I'm not certain about the 5.4, but I know for a fact that December 2007 (middle of 2008 model year) is when the 3-valve 4.6 engines got the newer design spark plugs. Anything built after December 2007 should have no worries on spark plug changes.
When I do them, I use a light coating of anti-seize because the threads are so long on these new plugs Ford is using and it's just peace of mind later down the road.
Old 03-08-2016, 06:12 PM
brokenleg brokenleg is offline
brokenleg has a good reputation on FTE.brokenleg has a good reputation on FTE.
Quote:
Originally Posted by tvsjr View Post
Yep. One big idea. Go buy a new keyboard, because apparently your punctuation isn't working properly. Once done, rewrite your post into something approximating English.
Old 09-28-2016, 09:26 PM
daboyce67 daboyce67 is offline
daboyce67 is starting off with a positive reputation.
Hate to beat this dead horse some more but ... Took my 2010 F150 5.4 into dealership for plug change and was told I should prepare myself for the likelihood of higher charge due to potential for plugs being broken on removal. Everything I find online seems to indicate that the issue was resolved in '08, including the issued TSB, yet the dealer insists they've had the issue on other 2010 and later. Tried to get the straight scoop from Ford but they just kept referring to their dealer.
Am I being jerked by the dealership?
  #28
Old 09-29-2016, 08:11 AM
arno arno is offline
arno is starting off with a positive reputation.
Being jerked. Changed them in my 09 and it had the new design plugs. All came out with zero problems. 08 was the year Ford made the switch.
Any issues/advice for 2011 5.4 Expedition plug change? gibsonj 2007 - 2014 Expedition & Navigator 11 03-18-2017 09:13 AM
2009 5.4l valve cover torque canuck2a 2009 - 2014 F150 1 06-12-2016 11:42 PM
Part# SP-515PZH14F 6t56 Modular V8 (4.6L, 5.4L) 3 02-22-2012 10:26 AM
2009 5.4 Spark Plugs GCLL Modular V8 (4.6L, 5.4L) 6 10-25-2010 08:36 AM
Request your advice, should I keep my truck? Tahnka Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 32 10-07-2010 04:58 AM
Tags
2009, 2piece, 54, changing, chips, computer, engines, f150, ford, ltr, plugs, replace, replacement, replacing, spark, v8, years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
