3 on the tree? - Ford Truck Enthusiasts Forums
3 on the tree?
Old 03-27-2011, 01:29 AM
ocbp1981 ocbp1981 is offline
ocbp1981 is starting off with a positive reputation.
3 on the tree?
Does anyone know the rational behind having 3 on the tree shifter instead of a on the floor shift? When did the on the column start?
Old 03-27-2011, 07:01 AM
FourOneTons's Avatar
FourOneTons FourOneTons is offline
FourOneTons is gaining momentum as a positive member of FTE.
Generally speaking, not just for Ford Slicks, most floor shifts of '50s-'60s vintage are four-speeds, or "four on the floor." Five-speeds, or four speeds with overdrive were the next step up, but weren't that common until the '70s.
Column shift, or "three on the tree" became popular beginning in the '30s, although there were a few holdouts with three on the floor into the '40s.
"Three on the tree" at that time was considered by many to be a modern improvement over floor shift, particularly in cars, as compared to trucks. There were four-speed column shifts too, but once manual transmissions started commonly having more than three speeds or three speed with overdrive, the shifter moved back to the floor.
"Three on the tree" hung around as a base option until the 1980s for most makes. I think Chevy was the last to offer it on pickups. Not sure when Ford stopped offering it.
Joe
Old 03-27-2011, 10:03 AM
oldblu oldblu is offline
oldblu is starting off with a positive reputation.
I don't know if it is the official reason for column shifters, but it does make for more comfortable passenger seating for the person in the middle.
Old 03-27-2011, 11:08 AM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust Ziegelsteinfaust is offline
Ziegelsteinfaust is starting off with a positive reputation.
Remember this is before extended cabs, and no one wants to ride around and get elbowed.
My truck has a 3 on the tree, but for the life of me I can't imagine why people would want it instead of floor shift.
Old 03-27-2011, 11:25 AM
Broomfieldbum's Avatar
Broomfieldbum Broomfieldbum is offline
Broomfieldbum is gaining momentum as a positive member of FTE.
I heard somewhere, that Ford last offered 3 on the tree in 1983. I love the 3 on the tree, for 2 reasons.
1) Most people cannot drive them. IE my truck is nearly unstealable, and unborrowable.
2) I drive around with a baby seat in the truck for my daughter, and I couldn't shift if I had a 4 speed. It would hit the baby seat before I hit 2nd or 4th.
Old 03-27-2011, 01:33 PM
Quote:
Originally Posted by Ziegelsteinfaust View Post
...My truck has a 3 on the tree, but for the life of me I can't imagine why people would want it instead of floor shift.
Column shifts were easier to reach and faster in older trucks. They were attached to sychromesh transmissions too. A lot of older truck transmissions with floor shifts were slow, with long throws between gears, and spur-gear, or non-sychro in some or all speeds.
My first car ('55 Chevy) had three on the tree, but it's been about 30 years since I've driven any column shift manual (and way longer since the Chevy). It would take me a while to get used to one again.
Joe
Old 03-27-2011, 02:14 PM
shortwide's Avatar
shortwide shortwide is offline
shortwide is starting off with a positive reputation.
I find it more comfortable to shift with a column shift than with a floor shift.
Old 03-27-2011, 08:50 PM
Oldschool1962's Avatar
Oldschool1962 Oldschool1962 is offline
New Oldbie
Oldschool1962 is starting off with a positive reputation.
If I were restoring the truck to original then I would probably keep the column shift but..... I do want to have fun. Not a great power shifter using a comumn shift and I've always wanted a Hot Rod (car or truck) with a 4spd. As far as shifter throw, yeah I remember driving a tow truck. Talk about throw......it seemed to take almost 20 inches of throw going from 2nd to 3rd and then 3rd to 4th. Stayed out of First unless I was really lugging a load cause I would end up pounding the dash with my knuckles trying to get it in 1st.
The one Hot Rod car I owned was an auto. It was a 66 'stang with an original 289. I found a '69 351w out of a Mach 1 and would have converted it if it wasn't such a pain in the **** for those cars.
The Mach 1 the motor came out of was owned by a person I knew and he did the conversion from auto to 4spd. Never could get the thing to work correctly and most of it was because of the steering post and dash mount for the pedals and the clutch linkage mounting system between the engine compartment and engine. That was also the most difficult change I've ever seen done.
Old 03-28-2011, 01:10 AM
SuperSabre's Avatar
SuperSabre SuperSabre is offline
SuperSabre is gaining momentum as a positive member of FTE.SuperSabre is gaining momentum as a positive member of FTE.
I'm helping a guy do a concourse restoration on a '39 Lincoln Zephyr. '39 was the last year Ford had the three speed on the floor in its cars. The 1940 models changed to "three on the tree." GM had already made that change a year or two before. One of the big selling points was for the ability to "comfortably" seat three passengers on the front bench seat. The floor shifter took up valuable passenger leg room. In the case of the Zephyr, Lincoln made the most amazing convoluted floor shift linkage you ever saw, and hid it inside a center console, for model years '38 and '39 trying to get around the leg room problem, before giving up and changing the shifter to the steering column in '40. I'm not positive, but I think
pick-ups kept the 3 on the floor for a few more years.
Old 03-28-2011, 05:05 AM
hollygreenman hollygreenman is offline
hollygreenman is starting off with a positive reputation.
From Wikipedia:
"The major advantage of a column shifter is that the driver can switch between the two most commonly used gears without letting go of the steering wheel, by reaching the lever using the index and middle fingers".
Could of fooled me!
Old 03-28-2011, 05:16 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1950: Last year Ford offered a 3 speed floor shift in a truck.
Last year for 3 on the tree: 1986 (F150), 1987 (Econoline), 1977 (Bronco).
3 speed manual transmission discontinued in F150's (1986) / 1987 Econolines / 1977 Bronco's.
When people swap 3 on the trees to the floor on trucks, the shifter will usually end up under the seat, so mods have to be made.
Something else to consider. With the shifter on the floor, there are no associated parts, With it on the column, there are dozens.
The more parts, the more problems, and... Since all the automakers are really in the partsbiz, where over 80% of their true profit comes from, the more parts they sell, the more money they make.
SuperSabre: 3 on the floor passenger cars after 1940: 1961/64 Galaxie / 1965/73 Mustang / 1966/69 Fairlane/Torino / 1971/75 Maverick/Comet / 1978 Fairmont/Zephyr.
Old 03-28-2011, 07:28 AM
Quote:
Originally Posted by hollygreenman View Post
From Wikipedia:
Could of fooled me!
This is entirely possible in my 66 if you have hands large enough to palm a 16# bowling ball!!!
Old 03-28-2011, 07:40 AM
shortwide's Avatar
I was also going to say (and I see that it's already been stated here), that a column shifter allows for more passenger comfort in the front seat if you're trying to seat three people....or.....if your girl wants to sit right next to you.
Of course, in that case, there are some advantages to having a floor shift, if you know what I mean.
Old 08-01-2016, 11:56 AM
black34beard black34beard is offline
black34beard is starting off with a positive reputation.
Would you ever consider getting rid of your transmission?
Old 08-02-2016, 07:34 PM
64M100builder 64M100builder is offline
64M100builder is starting off with a positive reputation.
Hi there, I have a working 3 on a tree transmission attached to a running straight six out of a 62 f100, its for sale, I'm in BC Canada close to Vancouver.
Converting from 3 on the tree to a floor shifter GMbusa 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 12-14-2015 11:42 AM
Transmission question Cazman1955 1961 - 1966 F-100 & Larger F-Series Trucks 0 04-18-2015 07:22 PM
3 on the tree conversion?! jdigio1960 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 03-02-2011 09:41 PM
Last year for 3 speeds on the column? IDIDieselJohn 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 04-11-2010 01:01 PM
3 on the tree question TKKTommyboy FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 09-19-2006 10:52 AM
Tags
1968, 1978, 54, bronco, column, driven, f100, f150, ford, linkage, shift, speed, steering, tree, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
