Oil and coolant puking from degas bottle
Old 03-26-2011, 11:16 PM
olfordsnstone's Avatar
olfordsnstone
olfordsnstone is offline
A van I have been driving at work, with a 6.0, suddenly started puking oil/coolant (gray cream) out of the degas bottle. When I say puking, I really mean it was barfing a lot of this stuff all over the ground in a big puddle. By the time I realized it was happening it had used enough engine oil to where the dip stick didn't register any oil in the crank case. The gauges looked fine when I shut off the engine and it was running great too. The temp gauge did rise after shutting down the engine but still stayed within the operating range.
Does this sound like the oil cooler let go? Or head gasket? I am kind of thinking of the oil cooler as the truck was running great and was not showing excessive temperature on the gauge, which to me seems like a head gasket is unlikely... But I ain't no mechanic.
I think it is a 2006. I have been told that this engine hasn't had any mechanical issues in its 101,000 mile life so far. Yeah, that's right, 1000 miles after the warranty is over.
Any thoughts?
Old 03-26-2011, 11:46 PM
Unrealo4's Avatar
Unrealo4
Unrealo4 is offline
Your oil cooler has burst internally. Its now mixing oil with your coolant. The oil side has more pressure then the coolant side. You have to change out the oil cooler and egr cooler and flush with simple green HD until its clear. Then add coolant.
Old 03-26-2011, 11:48 PM
Unrealo4's Avatar
Unrealo4
Unrealo4 is offline
Btw DO NOT RUN THE MOTOR. Until you have the work done have it towed.
Old 03-27-2011, 05:06 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
You'll also need to change all the hoses.
Old 03-27-2011, 09:32 PM
olfordsnstone
Thanks guys!
Old 03-28-2011, 01:12 PM
hott-rodd's Avatar
hott-rodd
hott-rodd is offline
I did simple green until i was blue in the face, still got a little oil floating in the coolant until I did the vc9. That really cleaned the system. Wasted coolant by not cleaning it right the first time.
Old 03-28-2011, 10:07 PM
Young Gun's Avatar
Young Gun
Young Gun is offline
That sucks! You may look into a BPD oil cooler so you won't have this problem again.
Old 03-29-2011, 09:00 AM
olfordsnstone
BPD? Is that the "Bullet Proof" brand aftermarket oil cooler?
Old 03-29-2011, 07:09 PM
Young Gun's Avatar
Young Gun
Yes BulletProofDiesel - Darn-Near Bullet Proof Diesel Products for your 6.0
Old 03-29-2011, 07:28 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
to bad you didnt have a gauge would like to know what the ect vs eot temps were averaging when they blow
I know the ford spec is 15 ddegres eot over coolant
Arlo2131
02-16-2017 05:37 PM
Kdawg89
01-27-2017 07:53 PM
c mobley
64
08-17-2016 07:21 PM
shultzaberger
1983 - 2012 Ranger & B-Series
20
05-10-2016 05:19 PM
tfunk88
04-25-2016 02:47 PM
Quick Reply: Oil and coolant puking from degas bottle
