1990 Ford Bronco 5.8 351w - Page 2 - Ford Truck Enthusiasts Forums
Old 03-29-2011, 04:55 PM
b4hntn b4hntn is offline
b4hntn is gaining momentum as a positive member of FTE.b4hntn is gaining momentum as a positive member of FTE.
Number one is pull codes and get all passed, 11 or 111 whichever your system shows.
Mine is as peppy as I need. If you want to drag race, a 5,500 pound rig it may not be the best choice. Mine will hold in OD pulling trailer and not drop but 3 mph with cruise on the hills but, I usually am nice to it and not suck as much gas with the cruise off. I just "shoot the hills."
The three best improvements on mine have been all new vacuum hoses, oxygen sensor, and rebuilt PCM. It probably has 15-20 per cent more power than 40K miles ago. Other replacements have been ECM. ACT, ICM, Distributor stator, TPS, all Mototcraft. Ford racing 9MM wires, cap rotor, NKG v-groove copper plugs, MSD? can't remember popular brand red coil. timing chain set and staying with 10W-30 (not 40) oil. K&N drop in air cleaner. Running 11 bdtc timing.
Then see if you want to spend money on more flow.
Old 06-11-2011, 01:35 PM
Smillie Smillie is offline
Smillie is starting off with a positive reputation.
Thanks for all the help, I ended up doing RAM air and holding off on turbo or supercharging. But, I've run into a problem. Lately, after around 6 minutes of driving my bronco starts getting way too hot. After I parked the other day I popped the hood to see if I had a radiator leak or something and I felt the radiator hose to see if there was pressure and there was none and it was burning hot. Also, at the radiator end of the hose there is a hissing at the clamp, which I've re adjusted several times now. Any ideas as to what this might be?
Old 06-13-2011, 02:37 AM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
Thermostat is stuck closed. Replace it and the upper radiator hose if the leak/hiss cannot be fixed otherwise.
Old 03-06-2014, 04:45 PM
RoadKing13's Avatar
RoadKing13 RoadKing13 is offline
RoadKing13 is starting off with a positive reputation.
well one thing you didn't say is what you use the Bronco for.
that makes a difference, in putting you on a good path.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
delete 97puller Ford Truck Parts for Sale 15 04-08-2014 04:53 PM
test jr105 Testing..... 0 04-04-2014 08:10 AM
Tags
1990, 351, 351w, 58, 94, bronco, economy, engine, ford, fuel, ignition, mods, supercharger, truck, upgrade, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
