AIR Tube fix? - Ford Truck Enthusiasts Forums
AIR Tube fix?
Old 03-26-2011, 08:03 PM
str8sixman's Avatar
str8sixman str8sixman is offline
str8sixman is starting off with a positive reputation.
AIR Tube fix?
93 F150 4.9l. where my airtube meets exhaust pipe rotted off. i connected peices together with heater hose and clamps, and it held for a month and then hose crumbled and its leaking again. doesnt seem like there is enough room to reweld it, although that could be my inexp. with welding talking. any ideas? and what exactly is the point of AIR anyway?
Old 03-26-2011, 10:29 PM
Prof2113's Avatar
Prof2113 Prof2113 is offline
Prof2113 is starting off with a positive reputation.
If you are talking about the long injection tube with the 6 fittings, you can get one from pciinc.com with fittings for about $120. It took me about 10 hours to change it, though I was taking my time and cleaning up things along the way. You will need to be careful with the fittings, they are thin and like to warp so that the line wrench doesn't fit anymore. If so, I used vice grips to loosen them. Lots of penetrant helps, too.
Don't forget the upper intake gasket. And it helped to take the valve cover off on mine, as well, so pick up a new valve cover gasket, too.
Good luck!
1987 F800 hose?? Pete Kildow Large Truck 2 11-05-2013 10:19 PM
What is that 3 inch diameter hose above my intake snorkel for? chixdigit 6.0L Power Stroke Diesel 10 05-15-2006 10:24 PM
Upper radiator hose waldreps Ranger & B-Series 7 04-10-2006 05:25 PM
Compressor air line question rednekf350 Garage & Workshop 7 04-02-2006 02:48 PM
Fresh air heater to outside vent hose ? for 52 F-1 Wheels331 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 02-26-2006 10:07 PM
Tags
1996, 49, 49l, 93, 96, air, exaust, exhaust, f150, f250, ford, lightning, pulse, replace, rotted, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
