98 F150 klunk on front end
Old 03-26-2011, 04:21 PM
imlowr2's Avatar
imlowr2
imlowr2 is offline
I replaced the A arms on both sides and also replaced the lower ball joints. When I turn all the way to the right and back up in reverse, the front end makes a klunk noise which is pretty loud. It's coming from the drivers side. I've checked everything and everything looks good from underneath and no play in any of the linkages. Suggestions?
Old 03-26-2011, 09:13 PM
Anafiel's Avatar
Anafiel
Anafiel is offline
I know this may sound silly, but I chased a klunk/pop in my front end that sounds just like what you described for 6 months.
Replaced control arm bushings, ball joints, had the linkage gone over at least three times, checked and rechecked king pins, replaced spring isolators, on and on and on....
Turned out to be the lower shock mount. Bolt hole was elongated, and when I turned a certain way and just the right pressure was applied, I would get a pretty loud KLUNK!
That dang mount made me crazy!! Replaced the mount, and used a new shock bolt, and klunk went away.
Old 04-19-2011, 08:54 PM
79 bronc's Avatar
79 bronc
79 bronc is offline
I had a clunk coming from the right passenger side. Turned out to be worn leaf spring bushing toward the front spring mount. had all new spring bushings pressed in, and good to go.
SKresse
1999 to 2016 Super Duty
11-08-2012 11:31 PM
MtHydro
03-06-2012 10:40 PM
b4hntn
1978 - 1996 Big Bronco
03-20-2006 06:07 AM
ripcurl94
12-28-2005 09:38 AM
chrisgraz
11-21-2005 03:31 AM
Quick Reply: 98 F150 klunk on front end
