One More '73 Turn Signal Cam Posting
Okay, down to nitpicking details on my truck, got almost everything working now but the turn signals do not turn off when you go around the corner. Is this normally the cams that go bad or is it whatever clicks them that goes bad? The signal locks in either direction just fine. I checked and the whole switch assembly costs about $55 and I don't want to go buy one if it's not going to do the trick. What say ye all?
D3TZ-13341-A ..TSS-Use w/Manual Transmission / Available from Ford.
MSRP: $96.00 // FTE sponsor PARTSGUYED.COM price: $69.12.
D3TZ-13341-B .. TSS-Use w/A/T (1975/77: Use w/o Speed Control) / Available from Ford.
MSRP: $69.98 // PARTSGUYED.COM price: $50.39.
D5TZ-13341-B .. TSS-1975/77-Use w/Speed Control only / Obsolete
Available from Cleavenger Ford in Porterville CA for about $100.00.
Signal switch
I have the sae problem as this post indicates. Signal light work but wont turn off. I have a 75 f100. Automatic, but not the original column as the truck was a standard from factory. I have no info on the column or wheel. It does have a under cab NSS switch which is working so the column may be a 73-77??. How do I get the correct switch? Can I get numbers off the old one? I do not want to open it up until I have what I need.
Thanks
Ben
Thanks
Ben
1973/77: NSS located on steering column / 1978/79: NSS located on transmission.
1978/79 T/S switches different than 1973/77. There are 3 1978/79 switches: With Tilt Wheel / With A/T without Tilt / With M/T without Tilt.
Tilt wheel feature operates via the turn signal handle by pressing it forward.
Ford looped a paper tag over the T/S wires, has an ID number on it that includes 13B302
Mdc9966
12-05-2016 02:41 PM
asmith6
02-28-2016 08:56 PM
Adam Woolridge
12-07-2015 04:31 AM
freetorun
12-02-2015 12:53 AM
