lift kit
Early Bronco Restoration Full Size Bronco Restoration Classic Ford Bronco Parts For Sale is a good place to shop for these trucks
on
1 Post
on
1 Post
First off a bodylift is a waste of time and money. That **** is for people that refuse to do things the right way.
Heres the threads i told you about. Read each carefully. You also need to come to the understanding that this wont be cheap. If you want to do it right then youll have to read up and be prepared to shell out the cash.
https://www.ford-trucks.com/forums/9...-2wd-f250.html
https://www.ford-trucks.com/forums/9...s-of-pics.html
Also heres a link to the autofab stuff. top notch parts to say the least.
Autofab Offroad Trucks
if you want to do a bodylift dont go with the theory that they are for people who refuse to do things the right way. they are cheaper and i prefer them stacked on top of a suspension lift. anything above 6" on suspension gets to the point where you have to worry alot about pinion angles and durability. not a great problem to have for a street ride. i usually run 6" suspension and 3" body on all my trucks so i could get the height i wanted without all the headaches and money kits get stupid after 6" on the price usually. there are few things you need to know about them to make them look right though. move your bumpers up cause they look stupid when you leave the bumpers down. and if you have shifters that come through the floor cut and weld in extensions for the shifters dont cut your floorboard that looks awful. replace the cab bolts with grade 8 bolts for safety reasons. good luck with whatever you choose i always support lifting a truck even a 2wd. (i had a '90 2wd with 9 inches on it)
on
1 Post
Knowing you keep looking at the 73-9 forum i knew youd catch that.
Usually a lifted 2wd means prerunner. Seeing how those trucks are abused at high speeds a body lift doesnt seem like a good idea. Street drivin or mud truck doesnt really have the chance of getting barrel rolled like a prerunner does.
But im glad you pointed out the little things that you need to do when using a bodylift.
