What is the correct sealant to use on diesel fuel line threads? - Ford Truck Enthusiasts Forums
Old 03-26-2011, 12:07 PM
JimJr15 JimJr15 is offline
JimJr15 is starting off with a positive reputation.
I'm installing an aux fuel tank plumbed to my fuel filler neck. The kit from RDS doesn't tell me what, if any thread sealer I should use on the threads for the shutoff fitting at the tank, or the check valve at the filler neck?
I'm not sure if teflon tape is ok? Does anyone know what I should use on these threads. Everything is aluminum.
I searched for this, but couldn't find anything.
Old 03-26-2011, 04:10 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Permatex Teflon sealant would do the job, if you feel you need one at all.
Old 03-27-2011, 06:45 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.mistakenID is gaining momentum as a positive member of FTE.
Permatex makes a few thread sealant compounds that work well around diesel and gas. Also high temp thread sealants for engine sensors like temp, 02 exc.
Make sure you don't use a thread locker where you want a sealant!
Old 03-31-2011, 02:24 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
First thing to think about is the type of fittings you have. No sealant is used on flare fittings, compression fittings, and several other types, but a npt fitting requires it. Assuming you do need sealant,i believe teflon tape would hold up BUT its likely to have some loose pieces of tape inside that may clog up the strainer, so I would use a sealant that you apply as a liquid such as the permatex. The package should specify what it is and is not suitable for
Rear filler neck and hose... UGHHHHH smashclash 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 24 10-14-2015 02:31 PM
Filler neck '77highboy 1973 - 1979 F-100 & Larger F-Series Trucks 17 06-03-2014 08:23 AM
Crazy quesion about oil filler neck Dorifuta Aerostar 2 05-07-2012 02:40 PM
1965 Fuel Filler Neck Question F250GH 1961 - 1966 F-100 & Larger F-Series Trucks 3 11-11-2011 08:08 PM
What will happen if I route the vent hose fir the fuel tank back to the filler neck? myklstrng 1973 - 1979 F-100 & Larger F-Series Trucks 10 11-01-2010 12:06 PM
Tags
break, connection, cylinder, diesel, fuel, gas, line, sealant, sealants, sealer, selant, tape, teflon, thread, threads
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
