97 f350 garrett turbo wheel replaement
No such thing as a tow wheel but you can deffinetly replace the wheel, very easy to do and there about 100$ shipped-ish from robs turbo shop, the banks impellir wheel is not and upgrade for our trucks bit merely the same obs replacement wheel so don't get too excited if you find one. 6 or seven 12 point 8mm bolts and the comp housing is off. Take off the down pipe and get a ratchet with a small extension on the turbine wheel and back the compressor wheel off. The rod is very easy to stoop so just snug up the new wheel
*smacks steve*
It's RON's Turbo shop.
But clay sells them.
Buy from a site sponsor. =)
If you have bent fins, be sure to check for other things first.
The Wicked Wheel is a stock OBS wheel with a fancy name to trick people into buying it.
Thats fine if you send bob some money. He's a site sponsor too.
His OBS wheel is fairly priced last I remember.
And free o-rings, yay. I hope he sends you 2 sets.
cause your gonna have to order a second one from guzzles or him for your pedestal.
Never re-use old o-rings on the turbo.
You'll see why.
When assembling to tighten.
Tighten the turbo by hand.
Then give it one little snug with a wrench after that.
Otherwise you'll strip it out.
I did it cause nobody else would tell me how to tighten it. And my wheel was un-damaged. =*(
The wheel will tighten itself if it needs more.
Resistance from the air vs blah blah blah.
Whatever.
You'll see why.
Whatever.
on
UM NO!! Sounds like an easy way to buy a new turbo! The shaft is not very big. Chances are very good you will hit tight with the impact and even thought the shaft will free wheel it will be too tight at the least or break at the worst!
66 sandrail
01-03-2017 05:31 PM
Leatherneck007
18
05-13-2016 08:15 PM
