Dome light bulb replacement '09 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-26-2011, 05:39 AM
Larry NCKS's Avatar
Larry NCKS Larry NCKS is offline
Larry NCKS is starting off with a positive reputation.
Question Dome light bulb replacement '09
Hi folks,
I'm normally on the 6.4 forum, but have a question about bulb replacement in the dome light of an '09 E-350. The assembly appears to be the same as that of my '08 F-350.
Before I break something, what is the proper procedure to remove these from the headliner for bulb replacement? There is a slot in the rear center of the assembly. Might I assume that a small screwdriver inserted here will release some kind of latch? Thanks.
Dome light LT-OPA New Member Introductions 0 07-08-2016 07:01 PM
Interior & Running Board Bulbs LadyDi 1997-2006 Expedition & Navigator 6 07-09-2015 04:33 AM
No dome light, power windows or radio. *FIXED* tlcsr66 Excursion - King of SUVs 7 03-29-2015 09:57 AM
Dome Light Bulb # pyro2 1973 - 1979 F-100 & Larger F-Series Trucks 13 09-27-2014 01:38 PM
1989 F350 Lariat interior dome light bulb question lisagoud 1987 - 1996 F150 & Larger F-Series Trucks 1 10-03-2011 04:07 PM
Tags
08, 2003, 2008, bulb, bulbs, change, dome, domelight, f250, f350, ford, light, mm, replace, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
