TDC and Distributor
TDC and Distributor
On my '91 F-250 5.8L I line the notch on the edge of the harmonic balancer up with the timing pointer, and the ignition rotor points about 90deg. away from #1 cylinder's post on the cap. I turn the engine 360deg. and the rotor turns 180deg., 90deg. on the other side of the dist. cap post for cylinder #1. Shouldn't the rotor be at #1 firing position when the cylinder is at TDC compression stroke?
I need to pull the distributor to change the PIP sensor (cranks, but no spark). As long as the engine doesn't revolve, and the rotor is pointed the same as it came out, it seems like it would all work the same. Right????
There are a few of us like you describe.
Latest thought is the pulley can slip so the marks have nothing to do with
reality.
Either way, it wants to be the same as the one that (used to ) works.
To answer your question,
IF the new dist goes in the same way the old one came out, you think it would work, that is
IF it worked in the position it is in.
Another way to check is to pull #1 plug and put in a plastic drinking straw and turn the engine with a wrench and stop where you think TDC is.
The other topic is to make sure the driveshaft for the distributor doesn't fall into the oil pan IF it happens to be one of those.
reality.
If your just pulling the distributor to work on it you don't need to line up the timing marks , just mark the base where it goes into the motor , and mark on the dist where the rotor is pointing , put it back to the same position it came out , then check the timing with a light when your done....Lew
All good to hear. I will pull the distributor today and put a new PIP sensor in. I guess statistically, it should be the TFI module, but I followed the test procedure at:
easyautodiagnostics.com/ford_ignition_module/distributor_mounted_module_1.php -
It shows the PIP sensor is bad by process of elimination. Hope they're right! I'm a nearly down and out residential construction contractor. Ouch!
Thanks guys.
Thanks guys.
Not exactly sure except for process of elimination.
What Lew said was great, mark Everything and whatever you do, don't let that engine turn with the distributor out.
Hide the key, block the wheels, make sure it's in neutral etc etc.
We had one guy with a hot start problem so he heated his distributor with a hairdryer, and it wouldn't start.
Blew it off with cold air and it started,
actually did that to a few different components and made sure it was the pip sensor by heating and cooling.
Some people say it's better or easier to just replace the distributor than to take it apart to fix.
Reminds me that I want to get an extra dist from a junkyard.
Do your fuel pumps run for a second and then shut off? with the key Just in the 'on' position?
or do they keep running?
Pls keep us posted.
Pls keep us posted.
Ok, so the pumps come on and shut off when you turn the key to the on position. perfect.
If they keep running, it indicates bad capacitors in the eec that sorta duplicates your no spark problem.
Depending on what part of the country you live in, (salt etc)
a simple connector check, connector plugs, grounds etc can also be a consideration.
Dielectric grease is best for those connectors btw
I really hope it's a cheap and easy fix.
The heads are further apart on a 5.8 than a 5.0 since the cylinders are taller. That means the distributor shaft has to be longer as well. Thats one reason they aren't the same. The other is that the oil pump drive shafts are different. I believe the 5.0 is 3/8ths thick & the 5.8 is 7/16ths.
On an auto parts store website, you can look at the vehicles that a part is compatible with, and the TFI from the 5.0L works with the 5.8L and all kinds of Ford vehicles. I tried the junkyard module on my distributor and we have ignition. I was pretty careful checking connections when running the easydiagnostics, so I wonder if the procedure is flawed, or if I didn't follow it right.
Thanks to all for the support. You are good folks.
The TFI (ignition module)? Its fastened to the distributor with 2 screws. The electrical connection is several push in spades that point straight up toward the distributor cap. That's it. You're supposed to coat the contact area between the distributor and the module with silicone grease.
