1972 L600 ford
1972 L600 ford
I have a 72 L600 with a 390 and a five speed trans and a two speed rear. I was curious as to the adaptability of the five speed (390) to the 4x4 351m-400. I realize there is a difference in the flywheel housing bolt patterns, so I am mainly curious as to availability of flywheel housings and the possible transfer case attachment. Thanks.
are you sure that the engine is a 390 and not a 330 or 361 or 391 ? and the 5 spd should be a Clark and there is only one place that will take a clark and bolt up a transfer case to it ( Performance Gear of Lumberton, Ms (ph: 601 796 2026) )
you should be able to use the bell housing that was used for any 4spd !
Serving suggestion: horse trade that L600 stuff and adapt a ZF 5 speed to the 400. Bell to block pattern is the same as the 460, so you just need to find a 4x4 with a 460 as a donor. (easy for me to say).
There are a couple of other tweeks needed but check it out.
Thanks for the replys......This truck has a reman Jasper engine that shows 390 on the valve cover. I was not aware of the different engines for the bigger trucks. Good to know.
My thought was having an extra gear in the trans could allow a slightly higher gear in the drivetrain. I am probably better off with an overdrive and a little lower gear out back.
Different than norm is not usually better anyway......Thanks.
Catman 24
15
02-15-2011 04:30 AM
mositso
Engine Swaps
13
03-07-2010 07:30 PM
dazedandconfused
12-22-2008 06:54 AM
jpfreak
19
12-07-2005 01:29 PM
