Thanks
I do use this product.I had a tank start a fire at the area mentioned as I was using it..Tossed it to the ground and put out the fire...Thought It was operator error...still could have been,but good to know about other problems
Mark
i have three of these setups. knocked the one over and it ruptured. lucky the tank was empty. have always unscrewed the head since. some times the valve on the tank dont shut off. so dont smoke when removing head. after seeing this i feel lucky
MAPP gas is no longer produced.
These type of cylinders are still in use with other gases.
ANY cylinder under pressure is dangerous especially those with flammable/combustible materials.
Reusable pressure vessels require periodic tests for integrity.
BE SAFE
