No Limit IFS build progress - Ford Truck Enthusiasts Forums
Old 03-25-2011, 01:47 PM
SVT-F100's Avatar
SVT-F100 SVT-F100 is offline
SVT-F100 is gaining momentum as a positive member of FTE.
Here is the last thread to see any previous tear down.
http://www.ford-trucks.com/forums/10...-question.html
After removing all stock components and junk I went through the process nice and slow to try and assure I didn't screw anything up. (I hope)
I still need two castellated nuts for my rack rod ends, I need to figure out how much too tighten down my springs in the coilovers, buy some grease to pack my bearings, mount the rotors and my calipers. But for the most part that is normal mechanical bull.
Here is the tentative future plan. I will move onto the back install the No Limit 4 link then remove the cab finish cleaning the frame, install plumbing and then move onto drivetrain.
Moved pics around in photobucket so I am just posting a link to the album
http://s283.photobucket.com/albums/k...IFS%20Install/
Old 03-25-2011, 02:35 PM
Hammered Hammered is offline
Hammered is starting off with a positive reputation.
What Motor/ Trans are you going to run, and what lb. spring are you starting with on your coil overs?
Old 03-25-2011, 03:13 PM
SVT-F100's Avatar
I have 302 that I will be dropping in followed by an AOD (still looking for one). When I ordered the kit I told them my future set up I plan on running. The package for the rear springs said 200 and the front said 400 if I remember correctly. I hope that makes sense.
Old 03-25-2011, 03:55 PM
Old F1's Avatar
Old F1 Old F1 is offline
Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.
Very nice, and very nice work.
The coil over is certainly function and design at its ascetically pleasing best.
Your shop is way to clean.
Old 03-25-2011, 04:39 PM
I have a 400/ C6 w/ a Fatman MII, I put coil-overs on to test and needed 850lb to hold it up it rode great, I had 150 in the rear.
Very nice build pictures!
Old 03-25-2011, 04:47 PM
JRMack's Avatar
JRMack JRMack is offline
JRMack is starting off with a positive reputation.
Wow very nice looking set up..I'm jealous!
Old 03-25-2011, 05:32 PM
snook715's Avatar
snook715 snook715 is offline
snook715 is starting off with a positive reputation.
Beautiful! I feel pretty bad for not painting or having my frame painted. Yours looks great.
Keep the pics coming. Remember all those lil things are going to add up dont forget to keep a spread sheet or something to keep the bills in check.
Old 03-25-2011, 06:05 PM
SVT-F100's Avatar
Thanks for all the compliments. I was nervous while waiting for all the responses. I have done the build myself and have never embarked on something like this before. I got to thank FTE peeps, No Limit and Snook for helping a Novice like me out.
Which, in turn, is good for all the other guys just starting out that may be nervous on doing a full resto. My thoughts are "go big or go home" and build like you ain't you aren't scared! (even if you truly are) lol
I will get some more pictures up once I pack bearings. Thanks again
Old 03-25-2011, 06:16 PM
coolbeans's Avatar
coolbeans coolbeans is offline
Wyoming Chapter LDR
coolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant future
Thumbs up
That is coming along nicely!!
Old 03-25-2011, 07:14 PM
rzns60's Avatar
rzns60 rzns60 is offline
rzns60 is starting off with a positive reputation.
Nice Job, I am following in your's and the other guys footsteps, so it will be a lot easier with so much documentation. We are about to start stripping the frame to send out for blasting. Keep the progress coming.
Old 03-25-2011, 08:19 PM
SVT-F100's Avatar
Enjoy the build rzns it was a lot of fun so far with some po moments.
Remember to use the tech line at the shop. If they don't answer leave a message and they'll call back. I just got off the line with them and they are a lot of help.
I learned that they purposeful mount there coilovers upside down (left mine right side up). I can't explain it as well as him but made sense to me. Also answered a lot of novice questions o had to finish
Old 03-28-2011, 09:15 PM
SVT-F100's Avatar
Packed bearings, loaded up rotors and calipers
Old 03-28-2011, 09:25 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Quote:
looks fabulous!!... what paint are you using?
Sam
Old 03-29-2011, 11:45 AM
SVT-F100's Avatar
Thanks Sam!!!
I am using Rust o leum Hammered paint. For prep I used wire wheel and grinding disks then brushed on. I used a spray can to get inside the boxing plates as much as possible.
Old 03-30-2011, 09:45 AM
snook715's Avatar
Thanks Sam!!!
Looking great. im waiting for new rotors since I got those new wheels. Then a disc brake conversion for the rear. Keep up the great work.
55 F100/5.0 EFI build SVT-F100 1948 - 1956 F1, F100 & Larger F-Series Trucks 84 Yesterday 11:31 PM
How to rear hub seals and parking brake shoes camodown 1999 - 2003 7.3L Power Stroke Diesel 123 12-28-2015 10:42 PM
Build Progress (So Proud) snook715 1948 - 1956 F1, F100 & Larger F-Series Trucks 413 11-02-2015 06:36 PM
Project Sandy - Jaime's Project thread Jaime74656 1987 - 1996 F150 & Larger F-Series Trucks 268 09-11-2015 08:01 PM
(Build Thread) My 1995 F150 Flareside Ext. Cab NiftytheF150 1987 - 1996 F150 & Larger F-Series Trucks 10 11-22-2014 01:50 PM
Tags
1965, build, column, f100, ford, front, ifs, independent, limit, nolimit, nolimits, race, steering, suspension, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
