2008 climate control issue - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-25-2011, 10:41 AM
polaris192 polaris192 is offline
polaris192 is starting off with a positive reputation.
I have a 08 F350 diesel with dual zone climate control. In the winter the driver side heat seems to blow only cold air after the cab has reached the set temp. It will stay blowing cold air unless I bump it up 2-3 degrees, then it will blow heat again HOT until it reaches set temp ushally a few minutes, then it will stay blowing cold. The passanger side has no issues. I have read about electric actuators going bad, but would it still blow heat sometimes if it was bad? Is there a temp sensor that goes bad? Help winter is almost over and truck will be off warranty by next winter.
Thanks,
Tim
Old 03-25-2011, 02:09 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
If you put it to the manual mode...and adjust the temps that way what happens?
Old 03-25-2011, 03:04 PM
It still seems to blow cold air after a bit. I found if I leave the temp cranked and the fan on low I can keep constant heat. But if I leave it at 72 and have the fan on high or medium it will blow cold still.
Old 03-25-2011, 03:27 PM
senix's Avatar
sounds to me like there is something wrong with the EATC itself. Not the blend doors.
Old 03-25-2011, 08:33 PM
FireMe FireMe is offline
FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.
There are known issues with blend door actuators in trucks built before 11/06/08. Monitoring their operation with the proper scan tool can show if they are bad, which obviously requires replacement of one or both of the actuators.
The passenger side is easy to get to, the driver's side is around 5 hours labor for an experienced tech and requires removal of the evaporator core housing, recharging A/C system, etc.
Old 04-03-2011, 02:39 PM
Ciscokid8's Avatar
Ciscokid8 Ciscokid8 is offline
Ciscokid8 is starting off with a positive reputation.
I had the same issue, except that it was on the passenger side. I took it in and they told me the longest story in the world, meaning it was normal to have to continualy adjust... it didnt make sense. Now my heat is out all together...
Need help with dual climate control ghunt Cooling, Heating, Ventilation & A/C 0 10-18-2016 07:57 AM
Blend Door Issue BDSSUperDuty37 6.4L Power Stroke Diesel 4 03-16-2015 09:50 AM
Heater Trouble in my 04 Excursion, 6.0 atruscott 6.0L Power Stroke Diesel 19 12-25-2013 11:25 PM
2008 Heater Problem - Help?? texan2004 1999 to 2016 Super Duty 6 12-15-2010 10:24 AM
Expedition Rear AC not working chaneyb Cooling, Heating, Ventilation & A/C 1 06-21-2005 03:42 PM
Tags
08, 2008, climate, control, controls, drivers, dual, f350, ford, heat, heater, problems, ranger, side, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
