Stancor relay 586-902 vs OEM GPR warning........Maybe??
#61
I measured the 'initial' current draw at 160 amp two weeks ago. This was with the air temp @ ~ 40F. This was with a FLUKE Clamp Meter and it took a couple seconds from key on to check the meter.
Splitting the GP load across two relays would definitely extend their lifes as the current thru each would be halved...other than the mounting issues, seems straight forward.
Another idea would be to add a suppressor circuit across the contacts, something as simple as an R-C filter....just food for thought.
#65
No, it would have trouble energizing if at all. It's not the coil DC rating but the contacts current rating that is important.
#67
Is the 16VDC the max volts the relay can handle so presumably it will be more robust than the 902 which is rated at 14 iirc?
ZeroTucker
10-11-2016 11:30 PM
Stolher
Ford Truck Parts for Sale
03-12-2016 10:56 AM
bkuuz1
09-20-2015 07:36 AM
guzzle92
99
02-26-2010 07:15 PM
