New vehicle break-in period - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 03-25-2011, 06:27 AM
gmichaels gmichaels is offline
gmichaels is starting off with a positive reputation.
Howdy,
I'm taking delivery of a new 2011 Escape Limited 4wd today.
This is my first "new" vehicle purchase since I've been on the planet.
In order to celebrate (and even the score a bit), I was going to take my wife shopping around Chicago, about 2 hours away.
What's the word on the break-in period for this vehicle? Do I need to take it easy for the first few hundred miles?
-Greg
Old 03-25-2011, 10:34 PM
FireMe FireMe is offline
FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.
Congrats on the new vehicle.
First, RTFM, if I may boldly suggest. It will tell you 99% of what you need to know about everything on the vehicle. Even how to change the common light bulbs and perform other maintenance yourself.
Break-in is one of those topics where you will find many, many opinions. So many that you could spend several days on the net reading about it and only scratch the surface.
For me, as a Ford tech, I will suggest that for the first 500 miles you avoid long idle times, heavy trailer towing, long periods of wide-open throttle, and long periods of steady driving speed.
That last bit conflicts with your shopping trip, unless you plan on taking the back roads. It is important to vary the engine speed so that all moving parts operate together over a wide dynamic range, as different parts see different types of loads as the engine speed and power changes.
Also, I like to keep fresh oil in the engine as it breaks in, changing at 500-1,000-3,000-5,000 mile marks. But as I said, I'm a tech and can do this for very little money. You may not think it necessary nor economical to do this.
Old 03-26-2011, 07:28 AM
Thanks for the speedy reply. I will be digging into the manual over the weekend, just as soon as I get done playing with the Sync.
I was hoping for a "real life" opinion. Being a Ford tech, your answer was exactly what I was looking for.
The Escape is replacing a '99 Taurus with 145K miles. It still runs great. Frequent oil changes probably helped there.
I will be babying the Escape. I don't anticipate any problems, but if anything comes up out of the ordinary, I'll post it here so others can read/learn from it.
-Greg
Old 01-21-2012, 06:26 PM
rlastar rlastar is offline
rlastar is starting off with a positive reputation.
I will be buying a Brand New E350 van from out of state and will be driving about 800 miles (all Interstate Highway driving) to my home. I'll be going through the mountains the last 400 miles. How do you recommend driving it during this drive?
Thanks
Old 01-22-2012, 12:38 PM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
If I were doing the same thing, I'd try to vary the speed a little bit while on the flatlands. Take it up to your limit, then back off the gas pedal a good bunch and let it slow down to 15-20 mph lower, then accelerate back to your cruise speed, by any means you choose, either gently or with a bit of aggression. Backing off the pedal will raise intake vacuum, and pull a bit of oil or at least take the load off for a bit.
I pretty much did that with the vulcan in my old Sable that has gone 250k so far. Drove from Inpls to SF Bay area over two or three days, varying the speed pretty much the whole way.
You will have to face longer 'heavy load' times when climbing, but then can let off the gas completely on the way back down.
I did not bother with changing the oil until the car had thousands of miles on it. I figure the filter is there to do its job, and if the leftover machining 'chunks' were that big, they'd cause problems anyway. Everyone else will have their own opinion.
If the engine had just been re-ringed, I'd follow old advice of getting into top gear at around 45, and pressing as hard as possible on the gas pedal without an automatic downshifting, take it back up to 65 or so. Then coast back down again. Rinse and repeat about 10 times. Good load wide open will put pressure on the rings to get them to seat, without hi rpms. Vacuum on the coastdown will allow cooling and provide a bit of extra lube to the cylinder walls for those rings that are breaking in.
tom
Old 01-22-2012, 08:18 PM
scott91370 scott91370 is online now
scott91370 is gaining momentum as a positive member of FTE.scott91370 is gaining momentum as a positive member of FTE.
Thumbs up
Quote:
Originally Posted by FireMe View Post
...I will suggest that for the first 500 miles you avoid long idle times, heavy trailer towing, long periods of wide-open throttle, and long periods of steady driving speed...
This is what I tend to do. I have only had 3 new cars, one I sold with 115k, another lasted 200k (until the cooling fan died and the wife didn't pay attention to the temp gauge) and the third is currently at 227k (2004 Tribute). All of them have been great and never burned oil.
Have fun!!
How Important is Break-In/Do Ordered Vehicles Last Longer? Schlotzky 2015+ F150 31 01-07-2017 09:18 PM
How Fast Should I Drive?? AtypclEngr 1961 - 1966 F-100 & Larger F-Series Trucks 22 08-25-2012 06:25 PM
Automatic Transmission Break-In? yz450fpilot Clutch, Transmission, Differential, Axle & Transfer Case 8 08-09-2011 05:34 AM
Break-in period for a new 6.4 ponyboy123 6.4L Power Stroke Diesel 2 07-21-2009 07:18 AM
Engine break-in before towing dobimax 6.4L Power Stroke Diesel 19 05-10-2009 09:28 AM
Tags
2011, break, breaking, cyl, ecoboost, engine, escape, f150, ford, hybrid, period, properly, trucks, v6, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
