Steering Column - Ford Truck Enthusiasts Forums
Steering Column
Old 03-25-2011, 12:38 AM
lawdogg_78 lawdogg_78 is offline
lawdogg_78 is starting off with a positive reputation.
Steering Column
Ok...I have a 1976 Ford F-100 Custom 4X4. this evening I got into my truck and tried to start it, but she wouldn't turn over. this has happened before so I pushed my gear shifter (Automatic on the column) up into Park to seat it better. I heard a loud "snap" sound and I was able to start the engine. I had never heard the snapping sound before. I went to put her in reverse and back out of the garage, but the shifter was basically free floating and loose. It would not shift her into any gear. I got out and had my wife pull the shifter into gear while I looked at the linkage under the hood. Nothing moved. I'm thinking something broke off in the upper part of the steering column near the shifter. Is this common for these fords? Is this something they sell "top end column rebuild kits" for? Any help would be greatly appreciated.
Thanks
Old 03-25-2011, 02:30 AM
Dirt racer's Avatar
Dirt racer Dirt racer is offline
Dirt racer is starting off with a positive reputation.
It is common for the shift collar to crack and then it moves freely around the shaft. I have replaced mine twice on my 75 since I bought it back in 92. I think I bought the last one on ebay for about 20 bucks. Might be able to still get them at ford. I just checked at rockauto.com and they have the part for $16.32 and part number 83242. Ford part number D5TZ7228A. Under the Auto trans part Gear shift collar kit. It's been about 4 years but remember some of the stuff to do when you replace it. Remove the stearing wheel. You have to take the turn signal connector apart so you can remove it all the way. Remember siliconing some little bolts to a piece so I could get everything back together. Hope this helps.
Old 03-25-2011, 03:26 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Dirt racer View Post
It is common for the shift collar to crack and then it moves freely around the shaft. I have replaced mine twice on my 75 since I bought it back in 92. I think I bought the last one on ebay for about 20 bucks. Might be able to still get them at ford. I just checked at rockauto.com and they have the part for $16.32 and part number 83242. Ford part number D5TZ-7228-A.
D5TZ-7228-A (replaced C9TZ-7228-A & C5TZ-7228-A) .. A/T Shift Collar Kit / Available from Ford.
Fits: 1965/66 F100/250 / 1965/66 F350 (I-6 only) / 1967/77 F100/350.
Note: 1965/72: The pointer was made as part of the collar. 1973/77: The pointer is separate, made from plastic and slips into a slot in the collar.
The pointer (D3TZ-7A110-A-also available by itself) comes with the Ford kit, dunno about aftermarket.
Old 03-25-2011, 03:32 AM
78 PEB's Avatar
78 PEB 78 PEB is offline
78 PEB is gaining momentum as a positive member of FTE.
Not meaning to hijack here but good to see you on NumberDummy..............got a question for you. Have you ever heard of a remote drivers side mirror for a Dent? I heard a rumor about one, but have never seen one..........
Old 03-25-2011, 11:41 AM
Thanks guys....I was hoping it was something easy. I'm gonna take it apart today. I'll let you know what I find.
Old 03-25-2011, 02:01 PM
Quote:
Originally Posted by 78 PEB View Post
Have you ever heard of a remote drivers side mirror for a Dent? D3TZ-17696-K I heard a rumor about one, but have never seen one..........
And...there was a matching non remote right (passenger) side mirror: D3TZ-17696-L
These are similar to what 1967/79 Passenger Cars used, chrome with a squarish glass and hooded mirror. Were also available for 1967/72 F100/350's & 1966/72 Bronco's (but w/different part numbers).
The non remote, non hooded versions of these mirrors are the same as Passenger Cars (and are referred to by the idiotic name "Sport Mirrors" by repro parts sellers).
In fact, the left side (C7AZ-17696-A) was standard equipment on all 1967/79's, but...
No outside mirrors were installed at the factory, the dealers installed all the mirrors.
If the factory had installed the outside mirror(s) and the customer wanted something else, the holes in the door(s) would have to be filled in and then repainted.
D3TZ-17696-K & L = original applications: 1973/79: F100/350 & Bronco. The problem with these mirrors is...they are next to worthless for seeing anything out of.
btw: 1000's of the C7AZ-17696-A mirrors were THROWN AWAY by the dealers, because...every '67/79: F100/350, Bronco & misc Passenger Cars came with one, but next to no one wanted them.
One dealer I worked for had a 3' x 3' cardboard box full of them...all eventually went into the dipsy dumpster!
Old 04-18-2014, 10:19 AM
Zues1 Zues1 is offline
Zues1 is starting off with a positive reputation.
Gentlemen, I have the same issue. How do you get the wiring harness out of the way to remove the collar? It's attached to the turn signal mechanism on one end and has those big connectors at the bottom of the shaft. What am I over looking here?
Old 04-18-2014, 10:31 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Quote:
You have to remove the plastic plug.
First make a chart where each wire is located. Then, IIRC. there is a red plastic wedge in the plug that you pry out.
Each little wire terminal has a plastic lock tab that keeps it in place. Take a small screw driver and pry the tab away from the terminal and then pull the wire out of the socket.
Old 04-18-2014, 11:16 AM
Thank you for the fast response. I just figure it out. Pretty simple actually once you make a chart
Old 04-18-2014, 02:51 PM
VocaTexas VocaTexas is offline
VocaTexas is gaining momentum as a positive member of FTE.VocaTexas is gaining momentum as a positive member of FTE.
I may be a bit late here...make sure to tie a piece of wire (bailing wire, electric fence, etc.) to the lower end of the turn signal wires when you pull the switch. If you don't it will be very hard to get the wires back down the column.
Shifter collar replacement jdgarner13 1973 - 1979 F-100 & Larger F-Series Trucks 35 10-28-2016 06:47 PM
Automatic Steering Column Candidates for 69 w/ power steering mstpn2 1967 - 1972 F-100 & Larger F-Series Trucks 9 10-06-2015 08:21 PM
Moving shifter to the floor svolpone 1961 - 1966 F-100 & Larger F-Series Trucks 3 07-11-2014 08:41 AM
68 f250 shift collar? Curtis and Chrystal 1967 - 1972 F-100 & Larger F-Series Trucks 9 10-12-2011 02:22 AM
Need help with 1995 f250 column shifter Dufftrucks 1987 - 1996 F150 & Larger F-Series Trucks 5 09-13-2011 07:48 PM
Tags
1966, 1976, 66, collar, column, d3tz7a110a, f100, f250, factory, ford, mirrors, replace, shift, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
