36 gal tank swap? - Ford Truck Enthusiasts Forums
36 gal tank swap?
Old 03-24-2011, 04:59 PM
8LITERCOBRA 8LITERCOBRA is offline
8LITERCOBRA is starting off with a positive reputation.
36 gal tank swap?
I have a 2010 145" Screw 2wd with the 26 gal tank. There's a complete 36 gal tank off a wrecked 2009 I can get my hands on here locally. Does anyone know if I would have any problem swapping the tank out?? I plan to get the complete 36 gal tank, with pump, filter, sender, straps,etc.
Thanks for your comments.
Old 03-24-2011, 05:13 PM
Mgizler Mgizler is offline
Mgizler is starting off with a positive reputation.
I would think that is would be pretty straight forward especially since you are gettin all the necessary parts to do the job. I can take some pictures of my 36 gal if you need a reference.
Old 03-24-2011, 05:30 PM
I don't think there is any difference under the truck between the 4wd and 2wd that would effect gas tank placement/securing on the 36 gal tank. But I thought it would be worth the ask....we've all seen strange things that should have been easy!
Old 03-24-2011, 06:39 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
It should be no problem. Looking on the Ford web site at last years models specs and capacities, the 26 and 36 gallon tanks were available in all cab configurations. 26 gallon being standard and 36 being optional.
Let us know how it goes.
Old 03-24-2011, 06:51 PM
spdmpo's Avatar
spdmpo spdmpo is offline
spdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to behold
I'd love to put one in my '11. But since it is not offered as an option on the Ecoboost I'm wondering if it is a compatibility thing, or if Ford is just being hard headed.
Old 03-24-2011, 11:23 PM
Rancheroracer Rancheroracer is offline
Rancheroracer is starting off with a positive reputation.
I guess if the pumps are the same pressure/flow ratings it should work?
Old 03-25-2011, 12:01 AM
Eric Landstrom Eric Landstrom is offline
Eric Landstrom is starting off with a positive reputation.
Quote:
I think but do not know for certain that we'd need to make the fuel pump in our 26 gallon work in the 36 gallon tank because we've direct injection which is much higher pressure.
What we need to do is petition Ford of offer a 36 gallon upgrade as an accessory.
Old 03-25-2011, 12:07 AM
Yes, we'd need a parts guy to tell us if part #s are same for the two pumps. The tank option would've been better, you're right.
Old 03-25-2011, 06:27 AM
tseekins's Avatar
It seems like Ford is intentionally holding back some of it's cool ideas to help boost sales from year to year. I'll wager that the 36 gallon tank will find it's way into the 2012 EB trucks.
Old 03-25-2011, 09:10 AM
fwiw....I ran the vin # on the truck with the 36 gal tank. It has the same 5.4 motor I've got, so no fuel pressure/fuel pump compatibility problems there. The folks with Ecoboost would definitely have that issue. I cannot imagine that the all-in-one fuel pump assembly would interchange between tanks. The fuel pick-up point has to be a little deeper with the bigger tank.
Old 03-25-2011, 10:31 AM
Deluxe05's Avatar
Deluxe05 Deluxe05 is offline
Deluxe05 has a great reputation on FTE.Deluxe05 has a great reputation on FTE.Deluxe05 has a great reputation on FTE.Deluxe05 has a great reputation on FTE.
Personally, I miss the days of dual fuel tanks. My dad's '94 F-250 had them, and they were quite nice on the longer road trips.
Both my '09 F-350 & '08 Lincoln Mark LT dwarf that truck in size. Unfortunately, the only option for more fuel capacity in them is to go for an aftermarket replacement tank (like Transfer Flow's 46 gal.) and live with inaccurate fuel level & miles to empty readings or give up bed space for a transfer tank. The former is a more viable option, but those tanks carry a hefty price tag. A factory option would be a fraction of the cost, and it would be integrated into the system--i.e. no false instrument readings.
Old 03-25-2011, 10:48 AM
countryboy69's Avatar
countryboy69 countryboy69 is offline
countryboy69 is starting off with a positive reputation.
ecoboost's high pressure pump is on the valve cover. low pressure pump in the tank so it still may work to put the bigger tank on an ecoboost
Old 03-26-2011, 04:54 AM
fonefiddy fonefiddy is offline
fonefiddy is gaining momentum as a positive member of FTE.fonefiddy is gaining momentum as a positive member of FTE.
Quote:
Actually, the single 36 gallon tank gives You more volume than the old dual tank setup. With less parts to fail.
Old 03-26-2011, 06:31 AM
tseekins's Avatar
Quote:
100% agree with this. My front tank rusted out, the pump went bad, the transfer valve failed and the transfer switch was replaced as well during my ownership of the truck. It took Ford until the 1997 model change to realize that dual tanks were not in our best interests.
Now we get a 36 gal plastic tank. More fuel and less future hassle.
Old 03-26-2011, 07:23 AM
juneau76's Avatar
juneau76 juneau76 is offline
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
We have an older Chevy 3500 utility body with dual tanks in my Fire Dept. All I will say is what a hassle.
I love the 36 gallon tank on my truck. Good luck to the OP. Make sure you let us know how it works out. Pictures, etc.
37 gal. tank question ct diesel 6.7L Power Stroke Diesel 17 09-09-2016 01:18 AM
34 GAL in a 29 GAL tank? '02 F250 PSD PineyMountainRacing 1999 to 2016 Super Duty 2 02-21-2015 06:41 PM
Has anybody used the whole 44? dosecobanya Excursion - King of SUVs 22 06-18-2012 05:50 PM
Gas tank size? cgi2099 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 12-23-2011 03:07 PM
26 gal and 36 gal Fuel Tank JeffHann74 2009 - 2014 F150 35 11-15-2011 03:36 PM
Tags
2011, 2012, 30, 36, 98, aftermarket, capacities, ecoboost, f150, ford, gallon, gallos, ranger, specificstions, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
