Cracked Valve Cover - Page 2 - Ford Truck Enthusiasts Forums
Cracked Valve Cover
Old 09-20-2011, 07:14 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Not really... Most import engines with a timing belt will bend valves if the belt breaks. It's the nature of the beast and the SOHC engine had some teething problems when it was introduced in 97 and Ford did extend the warranty on them. Now they are pretty solid with hundreds of thousands of them running on the road. If you had the engine out to replace the right cassette you should have had all of them replaced. There are several special tools that must be used to time the cams properly. There is also a specific procedure that if not followed can allow one or both cams to move out of time. Hopefully whoever you have working on the engine knows what they are doing.
Old 12-19-2011, 05:05 PM
Winningpoint Winningpoint is offline
Winningpoint is starting off with a positive reputation.
Similar Problem
I'm having a similar problem. I have 2009 Explorer and it is in the shop for a cracked valve cover. It must be the one on the passenger side, because that is where the oil and smoke are showing up. I was told that the reason the valve cover cracked could be that the aftermarket oil filters may not have the by-pass valve that allows oil to flow when the filter is 100% clogged. This truck has NEVER missed a service. Does this make sense to any of y'all? I would expect it on a vehicle with 150,000 miles, but this one is at 45,000. It sounds like a defect to me. What say you?
Old 12-24-2011, 11:55 AM
jayton4 jayton4 is offline
jayton4 is starting off with a positive reputation.
Quote:
You should start a new topic instead of hijacking this thread.
It is always a good idea to stick with the Motorcraft oil filters because of the drainback valve. The drainback valve is for stopping the oil from draining back into the oil pan. The valve closes off, allowing oil to flow out, but not back in. This is so that your cams and stuff up top are not dry when you go to start the engine.
The thing about having a bypass valve allowing the oil to flow when it is 100% clogged sounds like a bunch of nonsense to me.
Also how any of this is related to a broken valve cover sounds like a bunch of nonsense. I think that the cause of your broken valve cover is from something else, but I could be wrong.
Old 12-24-2011, 12:04 PM
Cracked Valve Cover
It turns out the cracked cover was on the driver's side. I guess the oil was blowing across and back to end up on the oil filter. I checked with my garage and they do use a filter with the valve in it so even IF that were to be the cause, it isn't. I think the darn thing was torqued incorrectly from the factory, but can't prove it. There was nothing else wrong (like a cracked cassette) nor was there ever any warning lights. It never ran roughly or lost power. It's fixed now, and not leaking. Of course when I picked it up it had a shiny new sheet metal screw in the left rear...
Probably should have been a warranty issue. It's a company vehicle, so I didn't have to pay for the work (close to $800) but still annoys me.
Old 12-24-2011, 12:06 PM
Hi-jacking the thread
Sorry about that, I didn't intend to. I wasn't the first, though.
Old 01-06-2012, 11:45 AM
Wanna B GT's Avatar
Wanna B GT Wanna B GT is offline
Wanna B GT is starting off with a positive reputation.
Quote:
Originally Posted by fastback4 View Post
It is poor engineering that would have a timing chain guide wear out and break bending engine valves, sending debris thru the valve cover and hot oil onto a hot engine. My neighbors 2003 Explorer 4.0 at 131,000 miles did just that 2 months ago, as well as 2 of my employees 2003 4.0. All 3 owners 4.0 engines were damaged and all within 2,000 odometer miles of each vehical on the same side of the engine same place at the valve cover...Of course i love my 2003, 225,000 mile 6.0 Ford 250 diesel......lol
Thank you fastback 4 for explaining that to some that does not get the concept of bad engineering on cheaply made parts made of plastic, which is why the new upgraded tensioners are made of a more durable nylon that will withstand the friction of the chain. Geez, some people just don't get it.
Thanks again,
Wanna B GT
Knocking on freshly rebuilt 460 74jolene 1973 - 1979 F-100 & Larger F-Series Trucks 10 05-27-2016 06:00 AM
03 navigator Knocking, Ticking noise. Need advice!! danyboy 1997-2006 Expedition & Navigator 47 05-18-2016 06:33 PM
94 4.9L I6 knocking after overhaul cmoses 1987 - 1996 F150 & Larger F-Series Trucks 12 02-21-2016 06:43 PM
1990 5.0 Bronco Transmission Knock Ryan1994Wright 1978 - 1996 Big Bronco 3 08-04-2015 04:31 AM
Bad Oil Pump??? 88 5.0 bob1987f 1978 - 1996 Big Bronco 19 02-25-2011 08:29 PM
Tags
2004, 40, cam, cover, covers, cracked, explorer, ford, jb, leak, oil, overheated, sport, trac, valve, weld
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
