2001 Expedition Rough Idle When Warm - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 03-24-2011, 08:37 AM
caryhenry caryhenry is offline
caryhenry is starting off with a positive reputation.
I have an intermittent rough idle on my 01 5.4L that gets worse with engine temp. After a cold start it idles fine, after warming the engine it typically gets worse. However, on hot days or when towing heavy loads it is by far the worst. Sometimes when towing it's so bad that the engine will actually surge as I am rolling to a stop (this has happened twice, now). I have checked for vacuum leaks and found none. To me, the fact that it gets worse with increased engine/ambient temperatures makes me think sticking IAC valve. It makes sense that if the valve sticks a little on cold days, that warmer temps will cause the metal to expand and it will stick even more on hot days. Does that make sense. I planned to remove and clean the IAC this weekend to see if it makes a difference. Am I wasting my time here? Any other suggestions as to what the problem may be?
Old 03-24-2011, 04:16 PM
0gers 0gers is offline
0gers is starting off with a positive reputation.
I had a similar problem. Try pop off the IAC valve and clean it out. It's a 15 minute job.
Rough Idle/Engine Vibration scsmartt 1997 - 2003 F150 13 02-22-2015 10:15 AM
rough idle at start David Bender 1999 to 2016 Super Duty 2 12-27-2014 01:51 AM
As the temp rises, the no start hot issue gets worse. sportsdad 1999 - 2003 7.3L Power Stroke Diesel 13 06-08-2014 06:06 AM
Rough idle Fummins 1987 - 1996 F150 & Larger F-Series Trucks 0 01-18-2014 01:22 PM
My 05 6.0L runs rough when cold. WhiteBeast-05-powers 6.0L Power Stroke Diesel 15 11-09-2013 01:47 PM
Tags
2001, 2002, 54, 99, car, expedation, expedition, f150, ford, hot, ideling, idle, missing, rough, stop, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
