Transmission replacement. Auto or Manual?
See www.valair.com for the clutch. There's other options but these guys are top notch. I was told to ask for Gary or Dan. I ordered mine on Wednesday at 14:00 and received it on Thursday at 13:00!! That was no special shipping or anything. But as easy as changing a clutch is you could always use your donor clutch for a while too. I got about 6 months out of mine.
A donor F350 would be nice. I wish I had thought of that at the time. However , I did get a rockin deal on my donor that actually ran. By the time it was over I got all my swap parts, a ton of extra stuff, and sold various stuff and then the truck and came out somewhere between even and small profit. I initially put into it about what a decent auto rebuild would cost.
If you have the money for a BTS auto then that's the way to go. There's no handshaker in the world that can hang with those and a lifetime warranty too, dude. But they are a chunk of change...
i dont know what it would cost from the boneyard but i cant imagine getting the trans and everything needed off the truck clutch pedals and such that it would still be over $800-1000. i would replace the clutch prior to install.
4r100 is the auto sd trans. It is plug and play. The sd manual is a zf 6 speed. It will bolt on but requires some fabrication beyond what you probably want to do. Plus a sd donor will only yield you a transmission.
2x4 and 4x4 are not the same. Completely different tail housings.
6.9 won't work. Any 7.3 will though but pedals and stuff won't work from some of the earlier years. Best bet would be 9
#29
Thanks for the help. Okay, then, I know what I'm looking for. I'll keep my eye out for a supercab F-350 powerstroke 4x4 so I can go ahead and swap to a Dana 60 while I'm at it. That way, I can use the driveshafts from the 350 because I know that both the transmission swap and the axle swap would require different driveshaft lengths. I'll have a while to find one, because it'll be quite some time before I'll have the resources to pull this off. I just wanted to know what I was looking for. Thanks, everybody.
