1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
99' brake problem!bad hydro boost?
Old 03-23-2011, 09:20 PM
bboyle652's Avatar
bboyle652
bboyle652 is offline
I have a 99' f250 with 120k miles on it. i recently have found a problem while braking. when i stop initial braking is fine but wen i get almost to a stop the pedal gives out like half way really weird, i just changed the master cylinder. front calipers. front barke lines(superlift stainless steel) i bled the whole system frnt and rear at my friends shop. he thinks its the hydro boost . has any body had similiar problems? thanks for any info
Old 03-24-2011, 08:51 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Welcome to FTE.
Sounds more like air in the lines to me. How is your steering? Your power steering pump supplies the boost to your brakes. You do know to use ATF and not power steering fluid in the power steering pump?
Old 03-24-2011, 05:11 PM
bboyle652's Avatar
bboyle652
i no its not air in the lines i blead the every caliper 10 times each with a mechanic. if my power steering pump is goin bad could that be it. i dnt no wut else to change it doesnt happen every time i stop either, does it more when it is warm out. could be coincidence tho
1fast93stang
Large Truck
37
05-24-2023 04:00 PM
1badton
12-31-2022 12:56 PM
skoto1
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
03-15-2016 11:06 PM
dbdbb
05-14-2015 06:58 PM
bill11012
23
02-11-2010 02:04 PM
Quick Reply: 99' brake problem!bad hydro boost?
