99' brake problem!bad hydro boost? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-23-2011, 09:20 PM
bboyle652 bboyle652 is offline
bboyle652 is starting off with a positive reputation.
I have a 99' f250 with 120k miles on it. i recently have found a problem while braking. when i stop initial braking is fine but wen i get almost to a stop the pedal gives out like half way really weird, i just changed the master cylinder. front calipers. front barke lines(superlift stainless steel) i bled the whole system frnt and rear at my friends shop. he thinks its the hydro boost . has any body had similiar problems? thanks for any info
Old 03-24-2011, 08:51 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Welcome to FTE.
Sounds more like air in the lines to me. How is your steering? Your power steering pump supplies the boost to your brakes. You do know to use ATF and not power steering fluid in the power steering pump?
Old 03-24-2011, 05:11 PM
i no its not air in the lines i blead the every caliper 10 times each with a mechanic. if my power steering pump is goin bad could that be it. i dnt no wut else to change it doesnt happen every time i stop either, does it more when it is warm out. could be coincidence tho
Brakes/V10 to Hydro Boost 1badton Excursion - King of SUVs 65 11-23-2016 07:18 PM
Hydro Boost boiling over skoto1 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 0 03-15-2016 11:06 PM
Brake problem Chris71 Large Truck 6 03-18-2015 06:00 PM
hydro boost mod obs dieselman86 1994.5 - 1997 7.3L Power Stroke Diesel 5 10-18-2014 09:35 PM
Vacuum Brakes Tuxedo Scorpion 6.7L Power Stroke Diesel 28 03-18-2012 07:13 AM
Tags
02, 2000, 99, bad, boost, diesel, ecoboost, f250, f350, ford, hydro, hydroboost, hydrobooster, problems, raptor, svt, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
