Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
  #1 (permalink)
Old 03-23-2011, 05:53 PM
msorensen msorensen is offline
Garage is empty, add now
msorensen is starting off with a positive reputation.
88 Bronco II won't start
I have read forums and forums, many threads gone through the chiltons and still need help.
I was driving up the road the other day and the Bronco just died, no sign of anything just died.
I have replaced the TFI as I thought that was the problem, still not working. Grabbed a coil replaced it, but only getting 9 Volts from the coil, and nothing from the distributor.
I think that this might have something to do with the EEC but have no idea where to find that module at. Any help is appreciated I have tried 50 different things and not coming up with any answers.
Thanks guys
  #2 (permalink)
Old 03-23-2011, 06:55 PM
89broncoll 89broncoll is offline
89broncoll is starting off with a positive reputation.
did you check all your grounds and wires
  #3 (permalink)
Old 03-23-2011, 08:07 PM
Quote:
All grounds seem to be connected and I tore the wiring harness apart from the distributor over to the coil, and the one that goes to power. Everything pulled apart on that main harness that has a couple branches looks to be ok. Nothing melted no shorts.
  #4 (permalink)
Old 03-23-2011, 08:48 PM
hmmmm.....ok well im no where near a professional but on my truck it wouldnt start or do nothing. check your starter solenoid and wires.
  #5 (permalink)
Old 03-23-2011, 09:11 PM
starter solenoid is fine, it turns over but won't fire, there is no spark.
Thanks
  #6 (permalink)
Old 03-23-2011, 10:27 PM
Sorry I couldn't help
  #7 (permalink)
Old 03-23-2011, 10:53 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old, tired and grouchy
1993 Ford F-250
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
EEC is located behind the pass. side kick panel.
__________________
93 F-250HD SC 460 E4OD
96 Explorer Limited 4.0 V-6 OHV
93 Ranger Splash 2.3 5spd only 51,000 miles!
84 Ranger 4x4 2.8 V-6 5spd......450,000 miles, now on a brand new 2.8
Dave
Oregon Assistant Chapter leader: To join the Oregon Chapter, click HERE
  #8 (permalink)
Old 03-23-2011, 11:17 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
I don't know what 50 different things you've tried. I'm assuming this is a "starter works fine, but the engine just doesn't catch" kind of no start. First thing I would check: is it getting fuel? What is the fuel pressure? Are the injectors firing?
Are the spark plugs firing?
If you think it has to do with the EEC, I'd probably start by checking the EEC power supply circuit.
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
  #9 (permalink)
Old 03-23-2011, 11:22 PM
As I said I am getting 9 Volts from the coil, but nothing from the distributor, in turn meaning I am getting no spark........ Fuel is fine this is a spark problem, and i will look behind passenger kick panel and see if I can find anything relating to the EEC thanks.
  #10 (permalink)
Old 03-25-2011, 01:11 AM
fordtrucksj fordtrucksj is offline
fordtrucksj is starting off with a positive reputation.
You're problem is going to be the internal components of your distributor. Very likely the distributor magnetic pickup has gone bad. If there is no spark and you have ruled out everything else, this WILL be the culprit. Good luck!
Tags
1987, 87, 88, bronco, bronco2no, died, ford, ii, key, kick, panel, passanger, side, start, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
