aod trans interchangabilities
ok i need to know if i get a used trans"pic a part"from a 2wd lariat xlt,take off the tail piece and it fit in my 4wd t case?the yr spread is puting an 89 2wd on my 90bronco xlt 4wd.it would be great if it could be that simple,but im hoping i can take the 2 and make them into one
Unfortunately I have no idea. Hopefully someone else might have some insight for you. However, since you are talking about Broncos and the year's 89-90, maybe this section of the FTE forum would be better for you to put your post in?
1978 - 1996 Big Bronco - Ford Truck Enthusiasts Forums
Hope this helps.
Mat
Hope this helps.
Mat
fair67driver
08-01-2010 03:51 PM
