Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-23-2011, 04:42 PM
jonnybronco jonnybronco is offline
Garage is empty, add now
jonnybronco is new and has a neutral reputation at this point.
refilling propane tanks
I am doing a propane conversion for my 79 Bronco. I am having a hard time finding a tank(s) that fit my budget. I am considering getting a single manifold tank that will fit between the framerails where the orginal gas tank went.
I would like to have more fuel capacity and am considering buying a few extra forklift style tanks that I would mount to my spare tire carrier.
Can I hook these tanks up directly to the fuel line to the engine? I believe the forklift tanks are not DOT approved, so I am not thinking this will fly.
Is there an easy way to fill my main tank from these tanks that could be done on the side of the road rather quickly?
What issues might I have with this?
Thanks
Jonny
  #2 (permalink)
Old 03-23-2011, 05:04 PM
GIGGER's Avatar
GIGGER GIGGER is offline
Grumpy Canadian
GIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputation
Where are you getting all the parts to do run propane, I'm pretty sure these propane powered vehicles have to pass rigorous inspections quite often.
You can transfer propane to your vehicle using a tranfer tank wearing gloves as propane will burn skin on contact.
Propane is not economical any more.Do you plan on running a dual fuel setup?
__________________
Gerry-2006 F350 Lariat Superduty FX4 6.0L white crew cab, Edge CTS w EGT.....Official slackmaster # 23, SCT tunes by GEARHEAD
2006 Mustang Vert, Windveil Blue (wife)....2001 Focus ZX3 black (son)
1996 Explorer XLT 5.0L V8 black with Arctic poly plow, 2006 Explorer Limited V8
2010 Forest River SandPiper 345RET 39ft Fiver, avid winter hater
  #3 (permalink)
Old 03-24-2011, 11:48 AM
I am not running dual fuel. I built the engine with high compression specifically for propane. The vehicle is going to be a weekend warrior, so I am not too concerned about fuel economy for a daily driver. I don't have a tow rig, so I will be driving it to the trails I plan to run and don't want to worry about running out of fuel, especially with propane being harder to find than gas.
  #4 (permalink)
Old 03-24-2011, 01:27 PM
GIGGER's Avatar
Grumpy Canadian
Look for a tank off a motorhome camper that would have a propane tank to run the appliances & the furnace, That will get you a farily large tank with the braces already on it to bolt it up to the frame.
__________________
  #5 (permalink)
Old 03-24-2011, 03:16 PM
gasman6674's Avatar
gasman6674 gasman6674 is offline
1996 Ford F-350
gasman6674 is starting off with a positive reputation.
If and I mean IF you build a box that will isolate the tank from the passenger area you can put a bigger tank inside. the box has to be vented to the outside,the tank has to be remote filled and the relief valve has to be piped to the outside. If you don't want to build a box you can buy a tank designed for that type of install, it has a metal box that covers the valves so that you can fill it, vent it etc from the outside. Unfortunitly if you can't find a used one from say a retired taxi or squad car they aint cheap. If you are wheeling be sure to skid plate and protect your tank and lines if they are under the truck.
PS a motorhome tank usally will not work as it does not have a liquid withdrawl valve to supply the engine, most are vapor only
Good Luck
__________________
Jim England
Do you have Gas? Propane Execeptional Energy
2012 Escape Ltd FWD, 2005 Explorer Sport Trac 2WD
2004 Escape Ltd FWD, 1996 F350 7.3L CCLB DRW,3" DP,4" Exhaust, Cat Delete, 6637
2012 V-Cross V27FK Super Lite by Forest River TT
  #6 (permalink)
Old 03-24-2011, 04:10 PM
GIGGER's Avatar
Grumpy Canadian
A motorhome tank will work if the motor also ran on propane, thats why I mentioned dual fuel, because thats the type of tank Jonny will need.
Everything else you said is also true Jim.
Usually the high rise camper vans ran on dual fuel..........
__________________
  #7 (permalink)
Old 03-25-2011, 07:23 AM
gasman6674's Avatar
1996 Ford F-350
Over the road engines due to horsepower requirements use a liquid withdrawal system. There is a unit under the hood that uses engine heat from the coolant to vaporise the liquid and regulate the pressure. If you try to run anything much bigger than a generator on vapor you will end up with a tanksickle (frozen tank no pressure) most (but not all) motorhome tanks are vapor only and not suitable for motorfuel. It looks like from his post that he has his engine set up for straight LP if he trys to run dual fuel (LP/gasoline) he will need to retard his timing due to spark knock
__________________
Jim England
  #8 (permalink)
Old 03-25-2011, 09:17 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
Quote:
Originally Posted by gasman6674 View Post
... If you try to run anything much bigger than a generator on vapor you will end up with a tanksickle (frozen tank no pressure)...
That is why CNG vehicles will stop before the tank is completely empty. 200psi is the practical low limit. So, an eight gallon "gasoline equivalent" tank is usually good for more like seven in actual range.
  #9 (permalink)
Old 03-25-2011, 11:30 PM
Thanks for all the responses.
I have searched for a long time for a used tank that will fit between the frame rails and have the fuel capacity I want. I can't put a tank in the cab because I have a third row bench in the rear cargo area.
The tanks I would get if they weren't so expesive are 50" long and 12" diameter and I would run them over the rear axle. I have a 6" lift kit which will keep the tanks far enough away from the axle as long as they are offset to the side away from the pumpkin.
the best option I can find right now that fits my budget is a manifold tank that is 32" long (between frame rails behind the rear axle is 33") with two 13" diameter tanks.
What I am wanting to do is carry extra fuel in forklift tanks that I would mount to my spare tire carrier and refill my main tank from them when I get low. I am pretty sure it is possible to do it, but I think it will only work if the tank can feed by gravity into the other tank beause both tanks will be basically at the same pressure inside.
I also wonder about the legality of transporting fuel on the outside of my vehicl with forklift tanks, which I beleive are not DOT compliant.
Jonny
  #10 (permalink)
Old 03-26-2011, 07:50 AM
GIGGER's Avatar
Grumpy Canadian
Not sure about AZ, but in Canada the law says we cant transport more than 5 tanks at the time & on & on.............
__________________
  #11 (permalink)
Old 03-26-2011, 11:23 AM
Elderstarr's Avatar
Elderstarr Elderstarr is offline
Elderstarr is gaining momentum as a positive member of FTE.
Might be worthwhile to check out these guys... Home*-*Propane Performance Industries Development Technolgy Systems -Cutting Edge Technology in Propane Gas Tanks
Their tanks are conformable to fit into tight areas, giving extra capacity.
Not sure on the cost though... might be pricey.
__________________
1987 F-250 Ext/Cab: LPG 351W, 6" Lift, D44 SAS, ZF5
In paint & bumper reconstruction. Wait for upcoming Vulgarity
Tags
33, close, cylinder, ford, forum, frederick, lift, maine, md, operations, propane, refill, tank, truck, users
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
