power steering assist ram... has anyone cut one open?
well my power steering assist cylinder is starting to leak. I like having it and want to keep it. but i am wondering if anyone has cut it open and rebuilt it? im a good welder so im not worried about the welding mainly the cutting. does anyone have pics or has anyone done it?
Are you sure it needs to be cut open ,then welded ? That don't sound right, I was going to rebuild one with a rebuild kit,never expected to cut it. If that was the case i would buy a rebuilt or new one. I don't see how it could be welded back with out doing damage to any seals or o-rings you would have just put in.
Don't have any pics of one cut open, but it's pretty self explanatory once you tear it down, if i recall correctly it only consists of (2) seals (1) o-ring (1) washer (1) snap ring......NPD use to sell the seal kit for $40, but i see they no longer have it listed, they still sell the reman'd cylinder for $225 though.
I took mine to the local hydraulic shop(the only major one in a 200k pop. city) and they said that it would have to be cut and welded and they wouldn't do it on a steering ram. I wish I would've checked my old cylinder when I had it off but I just thought that they'd know if they could just change the seals so I didn't worry about it.
Just to clarify things so we're all on the same page here, the stem seals can be replaced without cutting open the cylinder, it's the piston seals which require cutting open and then welding back together the cylinder, the stem seals are recessed about a 1/2" deep into the cylinder and can be a real bugger to remove/install without damaging the stem in the process, so some guys do choose to cut the cylinder open to install the stem seals as it's much easier with the stem removed and there's no risk of gouging or nicking the chrome plated stem, removal of the stem also allows you to polish out the groove that inevitably wears into the stem where it rides on the seal while driving straight, which is 90% of the time, my thinking is Ford just considered these cylinders to be disposable, hence their inability to be serviced very easily.
I ordered seal. I don't no if thay will fit.
I just ordered a seal kit from MAC's for a 63 galaxie 500 power steering cylinder.When I get them I will see if they fit. The push rod end of the cylinder looks the same as my F250's.
From what I can tell ford used the same seal on a lot years,and model cars.
