Any Ford Projects?
#77
Alright once again my truck is still sittin. But Iv gotten it out for "test drives" and installed some 37" Military OZs. Now the new problem is the c6 is takin a dump. I guess this last year of sittin did it in. Found a zf5 and hope its the bb not the diesel, so I can run it till my Cummins swap. With my wifes new job things will start rollin again!
By the way guys its all lookin SWEET, keep it up
#78
#81
I agree. I don't like them either. But I already got a list going and it's going to be EVERYTHING:
Siemens injectors - Deca 80s or 60s
Gap plugs to 0.040" for more boost
Get different cam to balance hp and torque
Fix PS pump
Install hpx sensor
install blower
Get PCM rebuilt
Wide band O2 sensor that also works with PCM
FULL PRESSURE NOW!
Fix PS pump
Install hpx sensor
install blower
Get PCM rebuilt
FULL PRESSURE NOW!
#82
So here's my project in action!
It's pretty much a bone stock 84 Capri 302, with a tuned Holly 700 Dbl-pump on it.
Upgraded exhaust manifolds to an H-pipe (open exhaust.)
This was the last run for this 302 as the 347 is getting dropped in come spring time!
Best pass ever was - 15.3 down in Tucson (with the old carb.)
I actually matched that here at Bandimere with the new Carb. So I can only imagine what it would have run down there!
This pass was 15.7, with a .083 reaction racing my buddy's 2012 6.2 Raptor (Stock).
Crossed the scale at the end with less than a 1/4 tank of fuel @ 3200lbs.
Just thought I'd post this - because I'm jones'n to put the new motor in!
https://plus.google.com/photos/insta...70265369488018
#83
So I had gottin the ole girl runnin and was drivin her to work. A friend of a friend had an 01 crewcab 7.3 that he let me have for a straight swap for my 85. This newer superduty aint like my old truck at all, besides havin an ideal drivetrain I dont much care for the superduty bodystyle. My plan is to keep the SD till I can find another truck just like my old one and swap axles trans and drop in a DT360.
#86
#87
Think I'm just about ready boys...take a look - https://www.ford-trucks.com/forums/7...l#post12794130
I had it running yesterday. Need to dial in the fuel more in the tune and work on idle and put some miles on it.
#89
Look'n good man.
I just found out that one of my wife's customers has a shop either in CastleRock or the Springs that has a dyno being put in. I may be bringing the Merc down for it's first official dyno test on it before I drop in the new 347 in a couple weeks.
I'll let you know so you can swing by.
#90
