2 pan oil change F150 5.0L
Finally got around to changing oil on our F150 pretty straight forward except drain points for oil with filter is removed.
For those that will change their own once the filter is removed there is a pan under filter to catch oil and it has 2 drain points one in front and one in back.. have 2 pans to catch the oil because they drain at the same time.. or one large enough to catch both as same time.. and before you put new filter on clean excess off pan best you can or it will leak out these drain points for a while.
Front drain point
Rear drain point
Mike
Front drain point
Rear drain point
Mike
Wayne64SS
61
03-01-2012 11:45 AM
