1951 Ford Truck Five Star Extra Cab Restore Follow-Up
#33
#34
Welcome to FTE LuLuBelle ,
Try looking for a stamp in the cowl on the driver's side toward the center. It will have your color code.
Here's a pic of mine to help you with the location. The first "H" is Silvertone Gray.
#36
Hi LuluBelle, welcome to FTE.
Check the colors of 1951 Ford Trucks to compare with yours. There´s only one gray color on 1951 ford trucks and that´s Silvertone Gray. It has a pale green tone. My truck has that color, you can see it almost ready on the second pic.
Look for the VIN number on your truck, you will be able to find it at the Rating Plate inside the glove box or stamped somewhere in the chassis. Mine was at the right front arm.
You can check the codes at thread #8. Silvertone Gray is "H".
If you still have any doubts come again to the FTE, if I´m unable to answer someone will, there´s lots of knowledge here.
Best luck.
Best luck.
#37
Yes, that will work if the truck was manufactured after September 4, 1951.
But my 1951 truck was manufactured in August, 1950 and does not have that style rating plate in the glove box. There is no color stamp on my rating plate. That, I suppose, is the reason I have the stamped cowl which includes the paint code.
By the way Al, I think your truck looks great in Silvertone Gray.
#38
#39
#42
