Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Illinois Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Illinois Chapter Join Chapter Leader: KOESTNER
  #1 (permalink)
Old 03-22-2011, 08:45 PM
MIAWLDR MIAWLDR is offline
Garage is empty, add now
MIAWLDR is starting off with a positive reputation.
wont stay running help!!
Ok as long as the key is held in the start position it will run but when i let it kick back to run position it dies.... Things I've replaced.....
Battery
ground cable
starter relay
starter
ecm/pcm
fuel pressure regulator
spark plugs
retimed
key lock cylinder
ignition switch
im getting 35 psi fuel pressure (while cranking and not)
I had ignition control module tested and it passed
I'm so clueless
Tags
2004, battery, changed, expedition, ford, started, stay, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
