IPR Screen Damage - Ford Truck Enthusiasts Forums
IPR Screen Damage
Old 03-22-2011, 09:05 PM
highsmit99 highsmit99 is offline
highsmit99 is starting off with a positive reputation.
IPR Screen Damage
Truck died on the interstate. Towed to dealership where they find damage to the IPR screen. They replaced the IPR and the truck ran fine. I drove about 150 miles home, shut off the truck and it hasnt started since. Took the IPR back out and it looks fine.They say the damage to the IPR to start with was probably caused by the screen below the oil cooler breaking apart and getting into the system. I took the oil cooler out and the screen was fine. What else could get into the system and cause damage to the IPR screen? HPOP?
Old 03-22-2011, 09:13 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
It would be nice to know what year truck it is. Also if you have any mods or if there was any recent work done on it ...........
Old 03-22-2011, 09:17 PM
embry1123's Avatar
embry1123 embry1123 is offline
embry1123 is starting off with a positive reputation.
Could be the HPOP. Have you tried unplugging the ICP sensor to see if it starts? Doing this tricks the computer into thinking there is enough pressure coming from the HPOP. If this works, replace the ICP... if not... might be time to look at the HPOP, but the fact that YOU shut it down and it didn't die on it's own, kinda makes me think it's not the HPOP, but then you never know, I've heard of stranger things. Checked your oil level lately?
Old 03-23-2011, 07:13 PM
Sorry the truck is a 2006 with 100700 miles on it! Just out of warranty. It has had no modifications. I unplugged the ICP and it still would not start. Mechanic at the Ford dealership says now it looks like the HPOP. Where can I get a good deal on one. Ford wants $820. If its not the HPOP what else could have put debris in the system and damaged the IPR
Old 03-23-2011, 07:25 PM
bismic's Avatar
Did you replace the screen while you were in there?
It would be good to know if there was a specific code thrown.
A bad HPOP could be the issue, but the later model HPOPs were generally pretty reliable.
The IPR could just have had lint on it from the oil filter. Did you see the original IPR that they removed? I wonder if you really don't have an issue w/ the STC fitting or dummy plugs/stand pipes - instead of the HPOP.
Old 03-23-2011, 07:57 PM
Yes there was a code, P2 291 Injector control pressure too low.
Old 03-23-2011, 08:01 PM
bismic's Avatar
I would bet it is a leak in one of the components I mentioned and nothing else.
Old 03-23-2011, 08:11 PM
ok but what would have damaged the first ipr? The mechanic said the screen on it was damaged like something had hit it and pushed it in.
Old 03-23-2011, 08:13 PM
The truck is still torn apart. Oil cooler and is out. I am deleting the egr and replacing the oil cooler while Im in there.
Old 03-23-2011, 08:19 PM
bismic's Avatar
Install the one-piece replacement for the STC fitting and dummy plugs. Maybe even get new standpipes also.
I would have liked to have seen the IPR screen.
Old 03-23-2011, 08:23 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
seeing an ipr valve get trashed from time to time is not uncommon. it happens. IMO bismic is on the money. we just dont see a large numer of pump failing on 05+ trucks. I dont think i have done one in about a year.
Old 03-23-2011, 08:33 PM
Thanks for the info. I will pull the cover off the pump tommorrow and check for leaks and maybe do an airpressure test. Hope yall are right.
Old 04-03-2011, 05:53 PM
Where can I get the fitting to screw into the valve cover in place of the ICP in order to do the pressure test?
Help! Early 04 no stqrt with new HPOP ddetrick78 6.0L Power Stroke Diesel 7 09-08-2014 11:20 PM
6.0 no start cummins0107 6.0L Power Stroke Diesel 21 11-12-2013 02:56 PM
Complete disassembly of ipr sidssm 6.0L Power Stroke Diesel 5 07-22-2013 01:12 AM
Metal shavings on IPR screen? Piolet 6.0L Power Stroke Diesel 0 02-20-2013 09:57 PM
A screen to clean on the IPR? Please read! landstorm 1994.5 - 1997 7.3L Power Stroke Diesel 5 02-27-2011 10:34 PM
Tags
05, 2005, 60, 60l, damaged, diesel, ford, happened, ipr, kit, number, part, replacement, screen, torn, unplugged
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
