1970 4x4 Crew Cab - Ford Truck Enthusiasts Forums
1970 4x4 Crew Cab
Old 03-17-2003, 01:00 AM
460 Crew's Avatar
460 Crew 460 Crew is offline
460 Crew is starting off with a positive reputation.
1970 4x4 Crew Cab
Hey group finally got some pics of my crew cab up if you'd like to check em out.Let me know what you think.
460 Crewcab 4x4 C6 460
Old 03-17-2003, 06:40 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
1970 4x4 Crew Cab
I wish I had that much time and money
I can't wait to see it done. It looked pretty nice just on the flatbed. Are you going to ditch the camper top?
Old 03-17-2003, 07:28 PM
460 Crew's Avatar
1970 4x4 Crew Cab
Yes the camper was the first thing to go it was hiddious. I actually thought I'd have it on the road in a month when I first got it because it looked to be in good shape but low and behold after I got into it a little there was this then that then before I knew it I was down to the frame and deciding what motor I wanted. Its definately been a learning experience as far as how much these trucks can get into your wallet especially a crew cab, 4 doors of rubber and all the goodies on and in them.
I've got lots more pics, if anyone is interested just mail me.
1970 Crewcab 4x4 460 C6
Old 03-17-2003, 07:57 PM
Alan P Alan P is offline
Alan P is starting off with a positive reputation.
1970 4x4 Crew Cab
Your truck is looking good. Very nice.
How did the new firewall cover work out?
This warmer weather and seeing a project like yours reminds me I need to get working on mine!
Alan P
Old 03-17-2003, 08:05 PM
460 Crew's Avatar
1970 4x4 Crew Cab
Thanks Alan, the firewall cover came out pretty nice and fit well. I did have to do some trimming around where I put the A/C, heater unit. and it was a little stiff but fits just right,I purchased mine from DC. Your crew cab pics are almost the same as mine except the color. the inside of these during construction becomes a storage container till your ready to do something inside. Give me a hollar if you have any questions as to where I purchased some of my stuff.
Old 03-18-2003, 10:52 AM
aerocolorado aerocolorado is offline
aerocolorado is gaining momentum as a positive member of FTE.aerocolorado is gaining momentum as a positive member of FTE.
1970 4x4 Crew Cab
460 Crew,
Glad to find your post right off the bat. I usually hang out in the Expedition and Aerostar forums.
I came here looking for any info anyone can provide regarding a 1971 4x4 Crew cab I am looking into purchasing. This truck has been a one owner, well cared for truck with 171,000 miles on a 390 engine, everything mechanical works with little evidence of unusual wear and tear. The steering is a bit sloppy and there is some associated front end vibration at speed. Otherwise, it seems very solid mechanically. Being too tall to garage, the truck shows evidence of a life spent outside - faded original paint, some rust holes at the rear cab corners and along the bottom door edges.
Any comments regarding this model from you or other knowledgeable members would be greatly appreciated, especially pros and cons to consider. I'm very excited at the prospect of possibly owning an ancestor to the Expedition.
Thanks in advance.
Old 03-18-2003, 01:40 PM
gdavis2265's Avatar
gdavis2265 gdavis2265 is offline
gdavis2265 is starting off with a positive reputation.
1970 4x4 Crew Cab
Hey 460 crew,
Could you give some more info on the AC/Heater combo. and how would i go about obtaining one? Also cost?
Thanks!
Old 03-18-2003, 06:52 PM
460 Crew's Avatar
1970 4x4 Crew Cab
Aero, these trucks are tough and getting rarer and rarer so if this one your talking about is in good shape then buy it if the price is right. If it does have anything wrong with it its usually an easy fix unlike newer stuff. The other good thing about the crews is that most of the parts are readily avaliable in the reg cabs except for a few specialty parts. I love mine and it's not even done yet, and I 'm sure I'll never sell it. If you have any questions just give me a hollar.
Glen, the A/C,heater'defroster combo unit I purchased was from Old Air products for around 1000 dollars but that included everything to put it on and every part it was like another 40 dollars for the adapter plate for the Saden rotary compressor to go on the York style brackets. I bought the complete package deal but you can also order stuff seperate to keep stuff lookin stock inside or outside. I opted to do this setup because everything on it is new and very available and the inside unit replaces the heater unit and is actually smaller,and also it blows harder than most units. Installation was fairly simple and ends up looking clean. The vents are mounted under the dash as you can see and still leave plenty of room to get under the dash if need be.If anyone needs a phone number just mail me.
1970 250 Crewcab 4x4 460 C6
Old 03-20-2003, 12:11 AM
Wask Wask is offline
Wask is starting off with a positive reputation.
1970 4x4 Crew Cab
Nice crew cab....
Old 03-20-2003, 12:49 PM
1970 4x4 Crew Cab
If the frame is not bent or rusted and the floors are in great shape (cab corners are minor) then I would go for it. The NP435 or T-18 will last almost forever along with the transfer case. Rebuilt motors are cheap.
Old 03-20-2003, 02:28 PM
1970 4x4 Crew Cab
460 Crew and recarbo,
Thanks for the supportive replies. When you suddenly run across a truck you know little about, and the window of opportunity is small, this type of help is certainly appreciated. I made the owner a very generous offer and am currently awaiting his decision. I am keeping my fingers crossed that shortly we'll all become better acquainted on this site. Thanks again for taking the time to respond.
Old 03-20-2003, 03:18 PM
gdavis2265's Avatar
1970 4x4 Crew Cab
Hey aero,
The rust is one of the easiet things to fix. I use an air cuttoff wheel and cut the entire rusted area out ( around it an extra 1/2" or so) then I trace that onto a piece of 16ga sheet and cut it out. then simply stich weld with a wire feed. Grinding and stichwelding over and over until its solid. You should have seen all the rust patches I had to deal with. Glad to see some old pre '73 crews on the road. I see lots of later models, but rarely see the early models. I just think they have a better classic look.
cheers.
Old 03-20-2003, 05:54 PM
460 Crew's Avatar
1970 4x4 Crew Cab
Aero
Good luck on your offer I hope you get it. Let us all know if you do and get some pics of it up.
1970 F250 Crewcab 4x4 460 C6
Old 08-05-2008, 10:26 AM
maddog crew 360 maddog crew 360 is offline
maddog crew 360 is starting off with a positive reputation.
Ford crew 360
Hey guys i am e new guy on the site and i just bought a 1970 f250 crew cab 4x4 360 and i am only 15. i was just wondering what kind of mpg's i might get since i cant be spending a load of money on gas when i only make 8.50/hr.
p.s i love your truck 460 but i can only get to two pictures.
thanx.... maddog
Old 08-05-2008, 07:18 PM
460 Crew's Avatar
With a well tuned engine and no power takeoffs you should see between 8-12 MPG.
Congrats on the truck!!
Crewzin70 - Photobucket - Video and Image Hosting A link to more photo's.
In my gallery here you have to click on the link to view the whole thing.
BEST fuel mileage out of the 1997 7.5L engine. low-blow00 1987 - 1996 F150 & Larger F-Series Trucks 21 08-25-2015 09:43 PM
looking to get a new daily driver Ravenwood Ranch Car/truck Buying Advice 1 01-29-2015 07:27 AM
Crew Cab Ebay 664x4drvr 1961 - 1966 F-100 & Larger F-Series Trucks 6 11-07-2014 04:36 PM
1990-1998 F350 crew cab 4x4 kaw753 WTB - Ford Trucks & other vehicles 6 07-27-2012 02:29 PM
Chassis Exit Headers (460) The Freak 1973 - 1979 F-100 & Larger F-Series Trucks 23 11-02-2009 08:34 PM
Tags
1970, 1970s, 1971, 1972, 4x4, 70s, 71, cab, crew, f250, f350, ford, highboy, quad, sale, spokane, truck, wa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
