1970 4x4 Crew Cab - Page 2 - Ford Truck Enthusiasts Forums
1970 4x4 Crew Cab
Old 08-05-2008, 06:32 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
I get 8 if i keep it at 55.
If i run side streets at 45 i can get around 14.
Nice Crew. I have a 472EFI with a C6 setting for my crew, Need to get the 63 going first then the crew will get redone. I picked up mine with only 46k original miles here in Arizona.
Garbz
Old 08-16-2008, 08:15 PM
maddog crew 360 maddog crew 360 is offline
maddog crew 360 is starting off with a positive reputation.
hey guys gears???????
i think that my truck has 456's because the guy i am buying it from told me that i could pretty much start out in third if i wanted to
now i dont want to redoo my gears to be able to get a better rpm rang so i am just going to put on bigger tires. i was just wondering if you knew of anywhere i could get a 4-6 inch susp lift for a good price????
oh i was just wondering how rare the original 1970 ford factory winch is???
Old 08-22-2008, 12:08 PM
iggybob44's Avatar
iggybob44 iggybob44 is offline
iggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant future
Are you certain the winch is a factory item? I know Jeep,IH,and Dodge Had factory PTO winches,IH used mostly Ramsey,Dodge used mostly Braden,and Ive seen Ramsey and Koenig on older jeeps. What brand winch do you have? BTW, the money you spend on bigger tires/wheels,and a suspension lift would likely buy a whole lot of gas! Have fun with it,but no matter what you do with a truck like this(short of putting in a diesel), your mileage is going to be poor
Old 08-22-2008, 12:28 PM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud of
i get 11 if i keep it at 55mph, with 3.73s out back, a C6, and 33 inch tires - the best way to get better MPG is to get an over drive for your truck.
Old 08-23-2008, 10:29 AM
i found out that i have 411's rear and 409's front
ya i found that out last night and as for the deisel i was already planning on puting in a 5.9 cummins in the future. also found out that my motor is from a 76 f250 but still the same. it has elec ignition but still want some more ignition upgrds but runs not to bad. seems like i loose alot of power in 3rd gear. as for you guys with the front end probs when you go fast ... i was going 72 and there was not a single vibration or anything.
Old 08-23-2008, 10:32 AM
oh and im almost positive but i havent took a real close look yet
BEST fuel mileage out of the 1997 7.5L engine. low-blow00 1987 - 1996 F150 & Larger F-Series Trucks 21 08-25-2015 08:43 PM
looking to get a new daily driver Ravenwood Ranch Car/truck Buying Advice 1 01-29-2015 06:27 AM
Crew Cab Ebay 664x4drvr 1961 - 1966 F-100 & Larger F-Series Trucks 6 11-07-2014 03:36 PM
1990-1998 F350 crew cab 4x4 kaw753 WTB - Ford Trucks & other vehicles 6 07-27-2012 01:29 PM
Chassis Exit Headers (460) The Freak 1973 - 1979 F-100 & Larger F-Series Trucks 23 11-02-2009 07:34 PM
Tags
1970, 1970s, 1971, 1972, 4x4, 70s, 71, cab, crew, f250, f350, ford, highboy, quad, sale, spokane, truck, wa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
