Truck is finished! Pics...Check it out! 1996 F250
#31
I am going to let it settle and then once it does I will get blocks that will make it sit a little more like the stock rake. It should come down a bit in the front over time. If $$$$ were no object I would have spent more on the tires.....But they arent cheap. I have put alot of $ into her over the last 4 months. All in due time.
#34
#36
it looks awesome, dont take off the factory wheels their the best lookin wheels. I went out of my way to get the factory alcoa stile ones for my F150. And good idea painting the underside, i did the same before winter but i used rustoleum, and sent it threw a cheap harbor freight gun i run with my compressor.
#40
Thanks, I'm not sure about tinting the windows(have thought about it)...You can get a ticket for that here. My old room mate got like 3. Yes the blocks are stacked right now cause that is what comes with the kit. I am planning on putting in 1 block once it settles so I know what size I want.
#42
When you do get tires this place sells them pretty cheap. The General Grabber AT2's are a good tire!
Save and Buy Tires Direct @ TiresDirect.Net
#43
#45
my thoughts , get the 4 inch rearched leafs and get rid of the rear blocks altogther. otherwise, yes it looks great! great job!
frame painting, i had used the rustoleum dirty metal primer and black paint, lasted barley a year , i am trying this time the eastwoods rust encapsulator with the rustoleum paint.
i hate the underside being all nasty!
