Oil change on 2011 - Ford Truck Enthusiasts Forums
Oil change on 2011
Old 03-22-2011, 05:40 PM
boomer08 boomer08 is offline
boomer08 is starting off with a positive reputation.
Oil change on 2011
Has anyone changed the oil on their 2011 F-150. From the looks of things every thing is covered up underneath the truck. I took the cover off that protects the oil pan but how in the heck do you get to the oil filter. I might just take it in for the first one and see exactly what they take off to get to everything.
Old 03-22-2011, 08:05 PM
cdmm151 cdmm151 is offline
cdmm151 is gaining momentum as a positive member of FTE.
I don't know about the Ecoboost but the filter on the 5.0 is accessible from underneath the front of the truck. I don't have to pull the skid plate off.
Old 03-23-2011, 06:07 AM
svt2205 svt2205 is offline
svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.
I'm guessing here because I've not yet looked under a EB powered truck. If your truck has skid plates, you do not have to remove them to access the oil filter. The filter is positioned directly above the front cross member and has a drain tray directly under it. If the EB is like my 5.0, you need a large drain tray because Ford gave you 2 places where oil will pour/drip from. One is the one you can see in front of the oil filter the other is located about a foot back. If you have skid plates, this is where there is a rectangular or square opening. This is the location where most of the oil comes out of. And if your EB is like my 5.0, it is really tough to wipe up the oil after you install the new filter. Some genius who does not do their own maintenance designed this set up.
Since we no longer have belt driven fans, you should be able to access the filter from above, if you can reach around the air intake plumbing.
Please post and let us know if the factory filter is on loose. Mine was. If your EB uses the FL-500S filter or another new filter. You'll need to either buy it online or at the dealer. Walmart doesn't carry these new one's yet.
Old 03-25-2011, 07:58 AM
ArtsBest ArtsBest is offline
ArtsBest is starting off with a positive reputation.
Since we no longer have belt driven fans.
Excuse me for asking but HOW are the fans driven now if there are no belts???
Old 03-25-2011, 08:43 AM
MCDavis's Avatar
MCDavis MCDavis is online now
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
Electric motors.
E-fans are said to reduce the amount of pull on the engine, thus being more efficient in the regards of fuel used.
Also the same reason that the 5.0 and EB have gone to Electric Power Steering instead of hydraulic like in years past.
I little less drag/pull on the engine here and there does begin to add up. Could mean 1-2mpg at then end of the day.
Old 03-25-2011, 01:26 PM
juneau76's Avatar
juneau76 juneau76 is offline
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
Quote:
Originally Posted by MCDavis View Post
Electric motors.
And this also allows them to run for a short time after the vehicle is shut off if the engine still needs to be cooled down.
Old 03-27-2011, 10:44 PM
F TOO FITTY F TOO FITTY is offline
F TOO FITTY is starting off with a positive reputation.
Quote:
I tried to change oil in my 09 the first time. Broke a filter wrench trying to get it off. Since I had already pulled the drain plug, this was a big pain in the butt. So I'm curious how the 2011's are sent out the door.
Old 03-28-2011, 07:52 AM
My 2011 was barely hand tight. Goes to show it doesn't have to cranked down to not leak.
Old 03-28-2011, 07:26 PM
Fasttimez's Avatar
Fasttimez Fasttimez is offline
Fasttimez is starting off with a positive reputation.
I found it easier to lean over the front of the truck (with the hood open obviously) and use the filter wrench to loosen the filter from up top, then spin it off by hand from underneath. I'm 6'3" so I have the length to reach it from up top. There's plenty of room since there's no belt driven fan.
Change Engine Oil Message Canadiancowboy 6.2L V8 3 07-04-2016 02:08 PM
2011 F350 6.7... trans leak?? see pic please Truckie256 Clutch, Transmission, Differential, Axle & Transfer Case 1 12-29-2015 05:59 PM
Covered under warranty markiemark 6.7L Power Stroke Diesel 14 05-26-2012 08:16 AM
2011 center consloe Bronc1 2009 - 2014 F150 1 03-06-2011 08:44 AM
Oil Filter stuck......help! myexpo02 2007 - 2014 Expedition & Navigator 18 01-16-2008 11:00 AM
Tags
2011, 4x4, 50, 50l, access, change, changing, diesel, expedition, f150, filter, ford, oil, specifications, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
