393 stroker - Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
393 stroker
Old 03-22-2011, 09:57 AM
tamndavereid tamndavereid is offline
tamndavereid is starting off with a positive reputation.
393 stroker
Okay this is what i got; Eagle 393 stroker kit, h beam rods, hyper pistons and rpm air gap intake, oh and 89 truck heads may have gt 40 if i need to, anyway this engine is going to be used in a marine application in a very heavy boat the problem is I dont know what kind of cam to use. Any help would be appreciated! Also will I have clearence issues with piston skirt to crank issues?
Old 03-23-2011, 06:41 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
I would guess that you need a cam that gives torque early, like an rv/towing cam. I doubt you will have any piston clearance issues if you got the pistons that are correct for the crank.
Oh, and welcome to the Iowa Chapter!
Old 03-23-2011, 09:47 AM
393 stroker
Thank you, and I did a little more research and decided to go with Lunati's 61002 cam. I think its really going to work well for my application and the price wasnt bad. I got the cam and lifters for a little over 210.00 bucs. I'll keep you guys posted on the build. I have to take my Eagle rotating assembly to get balanced today and that also is going to set me back a easy 200.00!
Where can I buy 1971 400 flat top pistons? 393STROKER 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 09-01-2011 01:08 PM
Which distributor should I look for 351w Gibby55 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 05-24-2011 03:41 PM
393 w/ stock 302 pistons wvroughneck Performance & General Engine Building 9 01-03-2011 02:19 PM
393 Pistons? kellar Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 18 11-09-2007 07:40 PM
compression of a 393 with flat top pistons? smallblock351w Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 02-28-2007 06:44 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
393, 393w, eagle, engine, f350, ford, fuel, heads, issues, marine, pistons, size, stroker, towing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
