"Lazy" Door Locks? - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
"Lazy" Door Locks?
Old 03-16-2003, 11:54 PM
jrahn jrahn is offline
jrahn is starting off with a positive reputation.
Question "Lazy" Door Locks?
I have recently noticed that sometimes the locks on the passenger side (Front & Rear) will not lock on the first attempt, rather they will make a "buzzing" or click...click..click, and the ***** will not hit the locked position.
Is this a common issue?
It is a sporatic problem, usually fixed by a few taps of the lock button. Is there someting inside of the door / lock mech. that I should lubricate, or perhaps a weak lock relay for the passenger side is the cause?
I am assuming that there are two relays 1 for D and 1 for P. Or I could be way off.
Can anyone advise?
Old 03-17-2003, 11:06 AM
brichardson brichardson is offline
brichardson is starting off with a positive reputation.
"Lazy" Door Locks?
Jrahn,
My 98 was doing the same thing. It was on both front doors. I replaced the power door lock actuators in each door and fixed the problem. It not difficult. Pull the door panel to access the part. It helps if you have small hands. Hope this helps.
Brian
Old 03-18-2003, 09:23 AM
"Lazy" Door Locks?
Thanks! I'll give that a shot.
Old 03-19-2003, 03:28 PM
Dit Dit is offline
Dit is starting off with a positive reputation.
"Lazy" Door Locks?
I have the same issue on my '98 but the door doesn't unlock instead. No problems locking the doors but sometimes it just won't unlock. Any ideas?
Power windows & door locks have suddenly quit working mrjimbov Electrical Systems/Wiring 7 11-23-2014 08:20 AM
power door lock issue jcopin 1968-2013 Full Size Vans 8 11-02-2014 03:22 PM
Door locks kglo Excursion - King of SUVs 2 06-28-2014 09:40 PM
power locks gjnicholas 1978 - 1996 Big Bronco 3 05-07-2010 09:53 PM
power door lock switch suburbanite Explorer, Sport Trac, Mountaineer & Aviator 3 08-10-2009 11:22 AM
Tags
03, 150, 2003, door, electric, f150, lazy, lock, locks, repair
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
