Cleaning out old fuel in lines question
I bought a 97 f-250 7.3 a few weeks ago and have a question about having bad fuel in the lines. Today I filled the front tank and the rear tank I filled to around 3/4 which had been empty. I drove around 90 miles home using only the front tank. Later I wanted to see if the rear tank worked because I had not used it yet. It ran fine for a mile or so and than starting knocking and stalled out. I assumed it was bad fuel in the lines and I put Diesel Kleen in both tanks but only used the front tank after that. It had a hard time running but eventually smoothed out and runs fine when using the front tank. Should I attempt to run the rear tank or will I damage by injectors doing that? Would my best be be to replace the fuel lines and all the fuel in the tank? Any advice would be appreciated.
SSellers
20
12-24-2013 12:47 AM
lud04X
12-03-2011 09:58 PM
eatont9999
09-18-2011 06:42 PM
