300 I-6 Mild Engine Tick. What do I do?
Heya Bill,
If its on the passenger side of the engine, it is probably something to do with the exhaust. A pinhole exhaust leak in your EGR tube, exhaust pipe, etc.
If it's on the driver's side, it very well could be your lifters, since they're under that access plate. If they're sticking, some Marvel's Mystery oil can sometimes free them up.
If it's coming from under the valve cover, then it's probably your rocker arms and such that're getting worn out.
If you can't find a stethescope, try a length of heater hose. Plug one ear with a cotton ball or something so no extra noise gets in, and then put one end of the hose to your ear (again, muffle external noise as best as you can with the hand that's holding it to your ear), and then move the hose around the engine pay, pointing it at the exhaust, lifter cover, and take the oil cap off and put it down inside the valve cover. The noise'll get a lot louder the moment you're pointed at the source. Works pretty well.
Just be glad it's not coming from the bottom end.
I found the stethescope and did my best to pinpoint the sound. I couldn't quite find the exact source of the sound. I'll get the old man to bend an ear to it as well. Truck seems to run fine for now.
Dad came home. I shoved the stehtescope up his nose and told him to find the sound. After removing the skinny end from my eye socked he jumped into the engine bay. After a few seconds he grunted a curt, "It's nothin'."
"It ain't nothing."
"Just a couple worn lifters. Look, put it here and listen."
So the verdict is; my engine is getting TIRED. Just some lifters. No big deal for now, so the Auto-King says.
One thing he did say I had to frown at was he suggested using High Mileage oil next change. What's everyone's thoughts?
"It ain't nothing."
