Removing front center console - Ford Truck Enthusiasts Forums
Old 03-21-2011, 04:29 PM
artfd artfd is offline
artfd is gaining momentum as a positive member of FTE.
I was looking at new Fords at the dealers today. The salesman said the only vehicle they have which lack the space consuming front & center console are some of the Ford pickups, although many of them have those space wasters also.
I'm 6' tall with big feet & back & knee problems.
One thing I used to like about pickups is the empty space over the floor hump to the right of the gas pedal. I like to put my right foot up there while in cruise mode, or maybe tip my right knee over the empty space. That's how my 2001 F150 is. The newer front center consoles prevent that & I wind up with my right foot in a narrow slot right over the gas pedal. The position is uncomfortable and eventually causes me pain.
I asked about this at the service counter and was told that some owners have removed the front center console to recover the space. Occasionally there are small wire bundles or electronic modules in there, but mostly it's empty and wasted space, this was per the Ford service people.
Has anybody done this?
Old 03-21-2011, 07:29 PM
81beast 81beast is offline
81beast is starting off with a positive reputation.
Just get a F150 that has the 40/20/40 split bench. An XL, STX, XLT, or Lariat can be had without the flow-through console.
Old 03-21-2011, 09:42 PM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
Or get an XLT. I've pulled the entire center consoles out of 09 and 10 models to install equipment consoles for communcations gear. Yes, lots of space wasted, but the RCM (airbag brain) is under there.
Old 03-21-2011, 11:03 PM
awq134's Avatar
awq134 awq134 is offline
awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.
The base of the console can be removed. I pulled mine out a few days ago to run some wires. There are two of the christmas tree type fasteners on the left side and one on the right. simply pull them out and finagle the trim around the cup holders/transfer case shift **** if applicable. The only downside is that the floor vent is right under the plastic piece and from what i saw really doesn't free up any space at all. I believe you would have to pull out the floor vent on the drivers side to free up more space.
Old 03-21-2011, 11:47 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
If you're talking about the flow through console that runs all the way to the dash, I guess you could remove it. But then what would you do with the floor shifter? Just a thought.
Anyway, as others have said, you could opt for the 40/20/40 split bench in your truck. Or, if you opt for an XLT, you can still get the buckets with a floor console that doesn't run to the dash......it pretty much stops even with the front of the front seats. It should provide you with enough room to avoid being cramped.
Old 03-22-2011, 12:43 AM
Quote:
IMO the floor shifter is another space waster, except in my 1983 F250. My 2001 F150 has a column mounted shift lever & a useful console that does stop even with the front of the front seats, so leaves a lot of space to tap the toes on my right foot when I'm cruising. I did get a look at the 40/20/40 split bench in a 2011 pickup, and that would work for me.
How big is the RCM module?
Old 03-22-2011, 10:00 PM
RCM is about 8" wide, 10" long, 2" thick. There are some heavy cast supports around it that the console bolts onto.
Be careful around this box and any wiring leading to/from it!
Old 03-23-2011, 03:29 AM
Quote:
Many thanks for this info.
Custom Center Console 03V10Excursion Excursion - King of SUVs 108 12-13-2016 10:43 AM
08 console conversion xmontex4 1999 to 2016 Super Duty 84 05-16-2014 09:43 PM
2008 console in my 2003 350 install. TennesseeMustangPerf 1999 to 2016 Super Duty 6 03-31-2013 10:03 AM
2011 F-150 Center Console Install Chris56ford 1994.5 - 1997 7.3L Power Stroke Diesel 11 08-06-2012 03:18 AM
Center Console... Ideas to make it useful... Anyone? LWW 1999 to 2016 Super Duty 0 04-27-2012 10:45 AM
Tags
2005, 97, center, console, consoles, empty, explorer, f150, f250, ford, recover, remove, removing, slot, top, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
